[Swift-user] Teragrid execution problem
Michael Wilde
wilde at mcs.anl.gov
Fri Mar 20 17:30:30 CDT 2009
that was indeed the case; this particular problem is solved.
On 3/20/09 3:22 PM, Michael Wilde wrote:
> Yue, I *suspect* that its simply that you are not mapped on abe.
> If you are around, stop by my office, and I can help you debug this, it
> will go faster than email.
> Looking on abe, I dont see your DOEGrids cert dn in the mapfile.
> Did you do a gx-request on abe?
> Can you do a globus-job-run of /usr/bin/id to the abe gatekeeper?
> On 3/20/09 3:00 PM, Ben Clifford wrote:
>> On Fri, 20 Mar 2009, Yue, Chen - BMD wrote:
>>> But I don't understand why it may fail, since I have performed
>>> grid-proxy-init and gx-request commands. Is it because the ftp server
>>> too busy?
>> I doubt it is because the server is busy. Email the teragrid helpdesk
>> at help at teragrid.org with your globus-url-copy demonstration above.
>>> I also tried SDSC clusters, but I got different error message. Is
>>> this also because of gsiftp issue?
>> Those error messages look different. For that, please can you put a
>> log file from that run somewhere where I can see it? (for example on
>> the CI NFS)
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
