[Swift-user] Problems in complex mapping situation
Michael Wilde wilde at mcs.anl.gov
Fri Mar 20 01:11:55 CDT 2009
I get this:
RunID: 20090320-0048-id8ot1y9
Progress:
Execution failed:
         java.lang.RuntimeException: Data set initialization failed for
result.[0][]/1. It should have been closed.
Caused by:
         Handle open: OOPSOut[] result.[0][]/1
SwiftScript trace: T1af7, Round, 0, Sim, 0, StartTemp, , TempUpdate,
Command exited with non-zero status 2
from the fairly lengthy script at www.ci.uchicago.edu/~wilde/oops.swift
This script was working fine, and I was trying to improve its
performance on large datasets on the BG/P by using an ext mapper instead
of simple_mapper to map a large 2D array of structures (OOPSOut result)
so that it spreads across multiple directories (to avoid the GPFS
locking issue. (I have 4K cores writing 14,000 files to one directory,
as I see no way with simple mapper to use the array index to, for
example, insert more directory entries in the prefix or suffix.)
So I am trying now to map the entire 2D array of structs "result" up
front (just handling the simple case where the first dimension has only
a single entry.)
The log is at the same URL, file oops-20090320-0048-id8ot1y9.log
In the simple first test case Im trying here (ie, map for one job), I
think my mapper is being called with and returning this:
int$ ./OOPSOutAll.map.sh -p 1foo -d out.n -r 1 -s 1 -t "" -u ""
[0][0].pdt out.n/1foo/0/00/00/ST.TU.pdt
[0][0].rmsd out.n/1foo/0/00/00/ST.TU.rmsd
[0][0].log out.n/1foo/0/00/00/ST.TU.log
int$
I'll debug this further, but am hoping you can give some clues as to
what the error above means. I dont get the idea of the dataset needing
to be closed at initialization. Is intialization here mean "mapping"?
The state notion implied by this message is confusing.
Thanks.
More information about the Swift-user mailing list
