[Swift-user] Teraport question
    Yue, Chen - BMD
    yuechen at bsd.uchicago.edu
    Thu Mar 19 17:21:21 CDT 2009
Hi Ben,
Thank you very much for the answer. After I changed to "fast" queue, it runs very quickly now.
Chen, Yue
Sent: Thu 3/19/2009 4:07 PM
To: Yue, Chen - BMD
Cc: swift user
Subject: Re: [Swift-user] Teraport question
You can run the qstat command to see if your jobs are being queued, what
state they are in, and which queue they went to. For example:
878629.tp-mgt             null             yuechen                0 Q
extended
shows a job submitted by you, that is in state Q (meaning queued) and that
it is in the extended queue.
There are a lot of other jobs running on teraport at the moment. You might
have more luck using a different queue, such as 'fast' which you can
specify by adding a line something like this:
<profile namespace="globus" key="queue">fast</profile>
to your site definition.
However, you'll likely still have to wait some time for your jobs to run -
that is the nature of using a job queue...
This email is intended only for the use of the individual or entity to which it is addressed and may contain information that is privileged and confidential. If the reader of this email message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is prohibited. If you have received this email in error, please notify the sender and destroy/delete all copies of the transmittal. Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090319/ca5bd3fd/attachment.html>
More information about the Swift-user
