[Swift-user] swift execution problem
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Mar 19 08:27:02 CDT 2009
Yue, what version of Swift are you using?
Please send the first few lines of your output file, where it says
something like:
Swift svn swift-r2701 cog-r2332
RunID: 20090319-0820-19zttiq9
(in fact please send the whole output file, stdout/err)
Ive tried to run your code in a near-identical test and I cant reproduce
the failure. Ive tried with both swift0.8 and the latest svn rev, and
both seem to work.
Also please can you post the pathname of the directory in which you are
testing (I assume you are running this on a CI machine?) so that I can
look at your logfile? And make it publicly accessible?
- Mike
On 3/18/09 6:32 PM, Yue, Chen - BMD wrote:
> Hi,
> I'm new to Swift programming. I was able to run a swift script before,
> but I couldn't run it now. I'm wondering if someone can help me figure
> out why. The swift script, sites.xml, tc.data, and all the error
> messages are copied in this email. Thank you!
> Regards,
> Chen, Yue
> Swift script
> type Fasta {}
> type PTMapOut {}
> type Solution {}
> type Inputfile {}
> app (PTMapOut ofile) PTMap (Solution sfile, Fasta fastafile, Inputfile
> input, Inputfile parameter)
>    PTMap  @filename(sfile) @filename(fastafile) @filename(input)
> @filename(parameter) stdout=@filename(ofile
> <mailto:stdout=@filename(ofile>);
> Fasta texts[] <filesys_mapper;prefix="fasta">;
> doall(Fasta texts[])
>   Solution sfile <"BSASolution.mzXML">;
>   Inputfile input <"inputs.txt">;
>   Inputfile parameter <"parameters.txt">;
>   foreach p in texts {
>     PTMapOut r <regexp_mapper;
>              source=@p <mailto:source=@p>,
>              match="fasta(.*)",
>              transform="\\1.out <file://\\1.out>"
>    r = PTMap(sfile, p, input, parameter);
> // Main
> doall(texts);
> sites.xml
> <pool handle="localhost">
>   <gridftp  url="local://localhost" />
>   <execution provider="local" />
>   <workdirectory >/var/tmp</workdirectory>
>   <profile namespace="karajan" key="jobThrottle">0</profile>
> </pool>
> tc.data
> localhost       echo            /bin/echo       INSTALLED
> INTEL32::LINUX  null
> localhost       cat             /bin/cat        INSTALLED
> INTEL32::LINUX  null
> localhost       ls              /bin/ls         INSTALLED
> INTEL32::LINUX  null
> localhost       grep            /bin/grep       INSTALLED
> INTEL32::LINUX  null
> localhost       sort            /bin/sort       INSTALLED
> INTEL32::LINUX  null
> localhost       paste           /bin/paste      INSTALLED
> INTEL32::LINUX  null
> localhost       PTMap   /home/yuechen/PTMap/PTMap       INSTALLED
> INTEL32::LINUX  null
> Error messages
> [yuechen at communicado PTMap]$ swift PTMap.swift
> Execution failed:
>         java.lang.NullPointerException
>         at
> org.globus.cog.abstraction.impl.common.task.ServiceImpl.toString(ServiceImpl.java:156)
>         at java.lang.String.valueOf(String.java:2577)
>         at java.lang.StringBuffer.append(StringBuffer.java:220)
>         at
> org.globus.cog.karajan.workflow.nodes.grid.GridNode.function(GridNode.java:31)
>         at
> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:45)
>         at
> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java:192)
>         at
> org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:33)
>         at
> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:335)
>         at
> org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:125)
>         at
> org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java:99)
>         at
> org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:173)
>         at
> org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:299)
>         at
> org.globus.cog.karajan.workflow.nodes.ExecuteFile.notificationEvent(ExecuteFile.java:163)
>         at
>         at
>         at
>         at
>         at
>         at
> org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
>         at
> org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:51)
>         at
> org.globus.cog.karajan.workflow.nodes.Sequential.childCompleted(Sequential.java:45)
>         at
>         at
>         at
>         at
>         at
>         at
>         at
>         at
>         at
> org.globus.cog.karajan.workflow.nodes.user.UserDefinedElement.childCompleted(UserDefinedElement.java:283)
>         at
> org.globus.cog.karajan.workflow.nodes.user.SequentialImplicitExecutionUDE.childCompleted(SequentialImplicitExecutionUDE.java:85)
>         at
>         at
>         at
>         at
>         at
>         at
>         at
> org.globus.cog.karajan.workflow.nodes.If.childCompleted(If.java:30)
>         at
>         at
>         at
>         at
>         at
>         at
>         at
>         at
> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:46)
>         at
>         at
>         at
>         at
>         at
>         at
>         at
>         at
>         at
>         at
>         at
> org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:27)
>         at
> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.executeChildren(AbstractFunction.java:40)
>         at
> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
>         at
> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:240)
>         at
> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:281)
>         at
> org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:393)
>         at
> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:332)
>         at
> org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:227)
>         at
>         at
>         at
> org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
> This email is intended only for the use of the individual or entity to
> which it is addressed and may contain information that is privileged and
> confidential. If the reader of this email message is not the intended
> recipient, you are hereby notified that any dissemination, distribution,
> or copying of this communication is prohibited. If you have received
> this email in error, please notify the sender and destroy/delete all
> copies of the transmittal. Thank you.
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
