[Swift-user] swift execution problem
Yue, Chen - BMD
yuechen at bsd.uchicago.edu
Wed Mar 18 18:32:46 CDT 2009
I'm new to Swift programming. I was able to run a swift script before, but I couldn't run it now. I'm wondering if someone can help me figure out why. The swift script, sites.xml, tc.data, and all the error messages are copied in this email. Thank you!
Chen, Yue
Swift script
type Fasta {}
type PTMapOut {}
type Solution {}
type Inputfile {}
app (PTMapOut ofile) PTMap (Solution sfile, Fasta fastafile, Inputfile input, Inputfile parameter)
PTMap @filename(sfile) @filename(fastafile) @filename(input) @filename(parameter) stdout=@filename(ofile <mailto:stdout=@filename(ofile> );
Fasta texts[] <filesys_mapper;prefix="fasta">;
doall(Fasta texts[])
Solution sfile <"BSASolution.mzXML">;
Inputfile input <"inputs.txt">;
Inputfile parameter <"parameters.txt">;
foreach p in texts {
PTMapOut r <regexp_mapper;
source=@p <mailto:source=@p> ,
match="fasta(.*)",
transform="\\1.out <file://\\1.out> "
r = PTMap(sfile, p, input, parameter);
// Main
doall(texts);
sites.xml
<pool handle="localhost">
<gridftp url="local://localhost" />
<execution provider="local" />
<workdirectory >/var/tmp</workdirectory>
<profile namespace="karajan" key="jobThrottle">0</profile>
</pool>
tc.data
localhost echo /bin/echo INSTALLED INTEL32::LINUX null
localhost cat /bin/cat INSTALLED INTEL32::LINUX null
localhost ls /bin/ls INSTALLED INTEL32::LINUX null
localhost grep /bin/grep INSTALLED INTEL32::LINUX null
localhost sort /bin/sort INSTALLED INTEL32::LINUX null
localhost paste /bin/paste INSTALLED INTEL32::LINUX null
localhost PTMap /home/yuechen/PTMap/PTMap INSTALLED INTEL32::LINUX null
Error messages
[yuechen at communicado PTMap]$ swift PTMap.swift
Execution failed:
java.lang.NullPointerException
at org.globus.cog.abstraction.impl.common.task.ServiceImpl.toString(ServiceImpl.java:156)
at java.lang.String.valueOf(String.java:2577)
at java.lang.StringBuffer.append(StringBuffer.java:220)
at org.globus.cog.karajan.workflow.nodes.grid.GridNode.function(GridNode.java:31)
at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:45)
at org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java:192)
at org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:33)
at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:335)
at org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:125)
at org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java:99)
at org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:173)
at org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:299)
at org.globus.cog.karajan.workflow.nodes.ExecuteFile.notificationEvent(ExecuteFile.java:163)
at org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
at org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:51)
at org.globus.cog.karajan.workflow.nodes.Sequential.childCompleted(Sequential.java:45)
at org.globus.cog.karajan.workflow.nodes.user.UserDefinedElement.childCompleted(UserDefinedElement.java:283)
at org.globus.cog.karajan.workflow.nodes.user.SequentialImplicitExecutionUDE.childCompleted(SequentialImplicitExecutionUDE.java:85)
at org.globus.cog.karajan.workflow.nodes.If.childCompleted(If.java:30)
at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:46)
at org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:27)
at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.executeChildren(AbstractFunction.java:40)
at org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
at org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:240)
at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:281)
at org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:393)
at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:332)
at org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:227)
at org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
This email is intended only for the use of the individual or entity to which it is addressed and may contain information that is privileged and confidential. If the reader of this email message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is prohibited. If you have received this email in error, please notify the sender and destroy/delete all copies of the transmittal. Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090318/a1b616b5/attachment.html>
More information about the Swift-user
