[Swift-user] Swift/PBS Scheduler Slow to Report "Finished"?
Andrew Boyce
ajboyce at jacks.sdstate.edu
Thu Mar 19 02:42:25 CDT 2009
Hello,
I am currently running Swift in conjunction with the PBS scheduler. My
annoyance at the moment is this:
When running any script, even a simple script such as first.swift
(which normally finishes almost instantaneously), Swift always takes
precisely five minutes to tell me that my job Finished successfully
and copy the files back to the appropriate folder. It is always almost
exactly five minutes; I've checked many logs - it polls the scheduler
for five minutes. When I run a script (like first.swift) without using
the PBS scheduler, everything happens as normal; execution and
"Finished successfully" are nearly immediate.
I think I know what the problem is: even after the scheduler says that
the job is 'completed,' (which is generally right away) the scheduler
keeps the job up on qstat and such for 5 minutes after (this setting
is a PBS server attribute known as 'keep_completed', and I have
checked that it is indeed set to 300 seconds; unfortunately I don't
have permissions to change it). So when Swift polls the scheduler, the
job is still up on qstat, and Swift must think that the task has not
yet "Finished successfully."
My question is this:
Am I indeed right that Swift does not "understand" that when the PBS
scheduler says a job is 'completed', the job really has "Finished
successfully"?
Can this be changed so that Swift does "understand" that a 'completed'
job has "Finished successfully"?
I have not included any files because I think I have narrowed the
problem down to a question that does not require those that I would
usually provide, but if I am wrong, then I can provide.
Thank you and sorry for the length.
Andrew Boyce
More information about the Swift-user
