[Swift-user] Does SWIFT_JOBDIR_PATH work for output?
    Ben Clifford
    benc at hawaga.org.uk
    Mon Mar 16 08:48:34 CDT 2009
On Mon, 16 Mar 2009, Michael Wilde wrote:
> Ah, I see: in wrapper.sh the "info" function which logs the env etc is only
> invoked on failure, it seems.  Unless you see an error in my sites.xml below,
> I'll add extra logging to wrapper.sh to see what my env is.  Or test with
> printenv as the app.
Yes, using env/printenv should be easy to do.
Are you using an unmodified Swift? Please can you send a log from running
something like first.swift, and its corresponding info file.
Also, try with that exact same Swift installation, but running on
localhost using the local provider and specifying SWIFT_JOBDIR_PATH.
More information about the Swift-user
