[Swift-user] class not found error from swift
Zhao Zhang
zhaozhang at uchicago.edu
Mon Mar 9 13:14:46 CDT 2009
got it, thanks guys!
zhao
Mihael Hategan wrote:
> I added the missing file in r2671. Sorry.
> On Mon, 2009-03-09 at 12:07 -0500, Zhao Zhang wrote:
>> Hi,
>> I got an error message for a sanity test of a latest swift:
>> zzhang at login6.surveyor:~/new_dock6> swift first.swift
>> Execution failed:
>> Fatal: Class not found:
>> org.griphyn.vdl.karajan.lib.ThrottledParallelFor
>> I check out the latest code, and build it, set PATH to the right dir,
>> then I try to run this example as I usually did, but it failed.
>> Below is the error message. Any ideas on this?
>> zhao
>> zzhang at login6.surveyor:~/new_dock6> cat first-20090309-1204-8ybqqe9f.log
>> 2009-03-09 12:04:14,695-0500 DEBUG Loader kmlversion is
>> >d1035a25-6ebd-404a-9b15-b03c27dc3bee<
>> 2009-03-09 12:04:14,695-0500 DEBUG Loader build version is
>> >f1b24b29-cc83-4ebd-affd-dc63ea733a1d<
>> 2009-03-09 12:04:14,695-0500 INFO Loader first.swift: source file was
>> compiled with a different version of Swift. Recompiling.
>> 2009-03-09 12:04:16,665-0500 INFO Karajan Validation of XML
>> intermediate file was successful
>> 2009-03-09 12:04:16,675-0500 INFO VariableScope New scope 663980386
>> with no parent.
>> 2009-03-09 12:04:16,706-0500 INFO VariableScope New scope 1395853665
>> with no parent.
>> 2009-03-09 12:04:16,706-0500 INFO VariableScope New scope 1358006625
>> with no parent.
>> 2009-03-09 12:04:16,710-0500 INFO VariableScope Adding variable t of
>> type messagefile to scope 1358006625
>> 2009-03-09 12:04:16,845-0500 INFO VariableScope Adding variable outfile
>> of type messagefile to scope 663980386
>> 2009-03-09 12:04:16,852-0500 INFO VariableScope thats the declaration
>> for outfile
>> 2009-03-09 12:04:19,089-0500 DEBUG VDL2ExecutionContext Fatal: Class not
>> found: org.griphyn.vdl.karajan.lib.ThrottledParallelFor
>> Fatal: Class not found: org.griphyn.vdl.karajan.lib.ThrottledParallelFor
>> kernel:elementdef @ vdl-lib.xml, line: 94
>> kernel:export @ vdl-lib.xml, line: 94
>> kernel:namespace @ vdl-lib.xml, line: 30
>> kernel:import @ vdl-lib.xml, line: 4
>> kernel:import @ scheduler.xml, line: 3
>> kernel:project @ first.kml, line: 2
>> Caused by: org.globus.cog.karajan.workflow.KarajanRuntimeException:
>> at
>> org.globus.cog.karajan.workflow.JavaElement.<init>(JavaElement.java:25)
>> at
>> org.globus.cog.karajan.workflow.nodes.ElementDefNode.post(ElementDefNode.java:57)
>> at
>> org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java(Compiled
>> Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:27)
>> at
>> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
>> at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:239)
>> at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:285)
>> at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:397)
>> at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java(Compiled
>> Code))
>> at
>> org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:227)
>> at
>> org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java(Compiled
>> Code))
>> at
>> org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java(Compiled
>> Code))
>> at
>> org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
>> Caused by: java.lang.ClassNotFoundException:
>> at java.net.URLClassLoader.findClass(URLClassLoader.java:378)
>> at java.lang.ClassLoader.loadClass(ClassLoader.java(Compiled Code))
>> at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:442)
>> at java.lang.ClassLoader.loadClass(ClassLoader.java:502)
>> at java.lang.Class.forName1(Native Method)
>> at java.lang.Class.forName(Class.java(Compiled Code))
>> at
>> org.globus.cog.karajan.workflow.JavaElement.<init>(JavaElement.java:22)
>> ... 12 more
>> at
>> org.globus.cog.karajan.workflow.events.FailureNotificationEvent.<init>(FailureNotificationEvent.java:36)
>> at
>> org.globus.cog.karajan.workflow.events.FailureNotificationEvent.<init>(FailureNotificationEvent.java:42)
>> at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.failImmediately(FlowNode.java:151)
>> at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:255)
>> at
>> at
>> at
>> Code))
>> at
>> at
>> Code))
>> at
>> Code))
>> at
>> at
>> at
>> at
>> Code))
>> at
>> at
>> at
>> ... 7 more
>> at
>> ... 12 more
>> 2009-03-09 12:04:19,118-0500 INFO ExecutionContext Detailed exception:
>> at
>> at
>> at
>> Code))
>> at
>> at
>> at
>> at
>> at
>> at
>> Code))
>> at
>> at
>> Code))
>> at
>> Code))
>> at
>> at
>> ... 12 more
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Code))
>> at
>> at
>> Code))
>> at
>> Code))
>> at
>> at
>> at
>> at
>> Code))
>> at
>> at
>> at
>> ... 7 more
>> at
>> ... 12 more
>> 2009-03-09 12:04:19,120-0500 DEBUG Loader Swift finished with errors
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
