[Swift-user] class not found error from swift
Ben Clifford benc at hawaga.org.uk
Mon Mar 9 12:14:05 CDT 2009
On Mon, 9 Mar 2009, Zhao Zhang wrote:
>        Fatal: Class not found:
> org.griphyn.vdl.karajan.lib.ThrottledParallelFor
Looks like r2665 didn't add that file when it should.
Mihael will probably add it when he sees this message.
In the meantime, you can force SVN to checkout version r2664 of Swift by
using the parameter -r 2665 with the checkout command (or use an older
installation).
More information about the Swift-user mailing list
