[Swift-user] class not found error from swift
    Zhao Zhang
    zhaozhang at uchicago.edu
    Mon Mar  9 12:07:39 CDT 2009
I got an error message for a sanity test of a latest swift:
zzhang at login6.surveyor:~/new_dock6> swift first.swift
Execution failed:
        Fatal: Class not found:
org.griphyn.vdl.karajan.lib.ThrottledParallelFor
I check out the latest code, and build it, set PATH to the right dir,
then I try to run this example as I usually did, but it failed.
Below is the error message. Any ideas on this?
zhao
zzhang at login6.surveyor:~/new_dock6> cat first-20090309-1204-8ybqqe9f.log
2009-03-09 12:04:14,695-0500 DEBUG Loader kmlversion is
 >d1035a25-6ebd-404a-9b15-b03c27dc3bee<
2009-03-09 12:04:14,695-0500 DEBUG Loader build version is
 >f1b24b29-cc83-4ebd-affd-dc63ea733a1d<
2009-03-09 12:04:14,695-0500 INFO  Loader first.swift: source file was
compiled with a different version of Swift. Recompiling.
2009-03-09 12:04:16,665-0500 INFO  Karajan Validation of XML
intermediate file was successful
2009-03-09 12:04:16,675-0500 INFO  VariableScope New scope 663980386
with no parent.
2009-03-09 12:04:16,706-0500 INFO  VariableScope New scope 1395853665
with no parent.
2009-03-09 12:04:16,706-0500 INFO  VariableScope New scope 1358006625
with no parent.
2009-03-09 12:04:16,710-0500 INFO  VariableScope Adding variable t of
type messagefile to scope 1358006625
2009-03-09 12:04:16,845-0500 INFO  VariableScope Adding variable outfile
of type messagefile to scope 663980386
2009-03-09 12:04:16,852-0500 INFO  VariableScope thats the declaration
for outfile
2009-03-09 12:04:19,089-0500 DEBUG VDL2ExecutionContext Fatal: Class not
found: org.griphyn.vdl.karajan.lib.ThrottledParallelFor
Fatal: Class not found: org.griphyn.vdl.karajan.lib.ThrottledParallelFor
        kernel:elementdef @ vdl-lib.xml, line: 94
        kernel:export @ vdl-lib.xml, line: 94
        kernel:namespace @ vdl-lib.xml, line: 30
        kernel:import @ vdl-lib.xml, line: 4
        kernel:import @ scheduler.xml, line: 3
        kernel:project @ first.kml, line: 2
Caused by: org.globus.cog.karajan.workflow.KarajanRuntimeException:
        at
org.globus.cog.karajan.workflow.JavaElement.<init>(JavaElement.java:25)
        at
org.globus.cog.karajan.workflow.nodes.ElementDefNode.post(ElementDefNode.java:57)
        at
org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java(Compiled
Code))
        at
org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:27)
        at
org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
        at
org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:239)
        at
org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:285)
        at
org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:397)
        at
org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java(Compiled
Code))
        at
org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:227)
        at
org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java(Compiled
Code))
        at
org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java(Compiled
Code))
        at
org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
Caused by: java.lang.ClassNotFoundException:
        at java.net.URLClassLoader.findClass(URLClassLoader.java:378)
        at java.lang.ClassLoader.loadClass(ClassLoader.java(Compiled Code))
        at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:442)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:502)
        at java.lang.Class.forName1(Native Method)
        at java.lang.Class.forName(Class.java(Compiled Code))
        at
org.globus.cog.karajan.workflow.JavaElement.<init>(JavaElement.java:22)
        ... 12 more
        at
org.globus.cog.karajan.workflow.events.FailureNotificationEvent.<init>(FailureNotificationEvent.java:36)
        at
org.globus.cog.karajan.workflow.events.FailureNotificationEvent.<init>(FailureNotificationEvent.java:42)
        at
org.globus.cog.karajan.workflow.nodes.FlowNode.failImmediately(FlowNode.java:151)
        at
org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:255)
        at
        at
        at
Code))
        at
        at
Code))
        at
Code))
        at
        at
        at
        at
Code))
        at
        at
        at
        ... 7 more
        at
        ... 12 more
2009-03-09 12:04:19,118-0500 INFO  ExecutionContext Detailed exception:
        at
        at
        at
Code))
        at
        at
        at
        at
        at
        at
Code))
        at
        at
Code))
        at
Code))
        at
        at
        ... 12 more
        at
        at
        at
        at
        at
        at
        at
Code))
        at
        at
Code))
        at
Code))
        at
        at
        at
        at
Code))
        at
        at
        at
        ... 7 more
        at
        ... 12 more
2009-03-09 12:04:19,120-0500 DEBUG Loader Swift finished with errors
More information about the Swift-user
