[swift-user] List of OSG sites
Glen Hocky
hockyg at uchicago.edu
Fri Jun 26 16:36:20 CDT 2009
that would be odd if it were necessary, since the only related thing i use
is
source /opt/osg/setup.sh
which only works on tp-osg
On Fri, Jun 26, 2009 at 4:34 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Fri, 2009-06-26 at 16:22 -0500, Glen Hocky wrote:
> > By the way, in reference to my previous e-mail. the result of my
> > condor status is:
> Yep, this means it's working, but there is no condor pool on tp.
> Erin, try this:
> source /autonfs/software/linux-rhel4-x86_64/osg-client-1.0.0-r1/setup.sh
> Then swift-osg...
> > condor_status
> > CEDAR:6001:Failed to connect to <128.135.125.117:9618>
> > Error: Couldn't contact the condor_collector on
> > tp-login2.ci.uchicago.edu.
> > Extra Info: the condor_collector is a process that runs on the
> > central
> > manager of your Condor pool and collects the status of all the
> > machines and
> > jobs in the Condor pool. The condor_collector might not be running, it
> > might
> > be refusing to communicate with you, there might be a network problem,
> > or
> > there may be some other problem. Check with your system administrator
> > to fix
> > this problem.
> > If you are the system administrator, check that the condor_collector
> > is
> > running on tp-login2.ci.uchicago.edu, check the HOSTALLOW
> > configuration in
> > your condor_config, and check the MasterLog and CollectorLog files in
> > your
> > log directory for possible clues as to why the condor_collector is
> > not
> > responding. Also see the Troubleshooting section of the manual.
> > which is different from yours. try putting @osg and +osg-client before
> > @default
> > On Fri, Jun 26, 2009 at 3:59 PM, Mihael Hategan <hategan at mcs.anl.gov>
> > wrote:
> > Doesn't work.
> > My .soft:
> > @default
> > @globus-4
> > +java-sun
> > +torque
> > +maui
> > +condor
> > @osg
> > +osg-client
> > [hategan at tp-login2 ~]$ condor_status
> > Neither the environment variable CONDOR_CONFIG,
> > /etc/condor/, nor ~condor/ contain a condor_config source.
> > Either set CONDOR_CONFIG to point to a valid config source,
> > or put a "condor_config" file in /etc/condor or ~condor/
> > Exiting.
> > On Fri, 2009-06-26 at 15:41 -0500, Michael Wilde wrote:
> > > If you added your swift/bin directory to your path manually,
> > when you
> > > run resoft you may loose that and need to do it again.
> > > On 6/26/09 3:33 PM, Hodgess, Erin wrote:
> > > > This is getting weird:
> > > > [erin at tp-login2 ~]$ swift-osg-ress-site-catalog
> > --engage-verified
> > > > -bash: swift-osg-ress-site-catalog: command not found
> > > > Erin M. Hodgess, PhD
> > > > Associate Professor
> > > > Department of Computer and Mathematical Sciences
> > > > University of Houston - Downtown
> > > > mailto: hodgesse at uhd.edu
> > > > -----Original Message-----
> > > > From: hockyg at gmail.com on behalf of Glen Hocky
> > > > Sent: Fri 6/26/2009 3:24 PM
> > > > To: Hodgess, Erin
> > > > Cc: Michael Wilde; Melinda Chin; Swift User Discussion
> > List
> > > > Subject: Re: [swift-user] List of OSG sites
> > > > It's likely this error can be fixed by the same thing Zhao
> > did to get condor
> > > > working last week (since the command works for me). Try
> > putting @osg and
> > > > +osg-client into your ~/.soft file and then resetting up
> > by either logging
> > > > back in or typing "resoft;source ~/.bashrc"
> > > > for reference, here is my ~/.soft file
> > > > @python-2.5
> > > > +java-sun
> > > > +osg-client
> > > > +maui
> > > > +torque
> > > > +R
> > > > +matlab-7.7
> > > > +apache-ant
> > > > +gx-map
> > > > @osg
> > > > @default
> > > > @globus-4
> > > > On Fri, Jun 26, 2009 at 3:20 PM, Hodgess, Erin
> > <HodgessE at uhd.edu> wrote:
> > > > > I'm having trouble with the
> > swift-osg-ress-site-catalog command:
> > > > > [erin at tp-login2 swift]$ swift-osg-ress-site-catalog
> > --engage-verified
> > source.
> > source,
> > ~condor/
> > > > > Exiting.
> > > > > <config>
> > > > > </config>
> > > > > Any help is much appreciated.
> > > > > Thanks,
> > > > > Erin
> > > > > Associate Professor
> > > > > From: swift-user-bounces at ci.uchicago.edu on behalf of
> > Michael Wilde
> > > > > Sent: Fri 6/26/2009 2:14 PM
> > > > > To: Melinda Chin
> > > > > Cc: Swift User Discussion List
> > > > > From a practical point of view, you can get the sites
> > in the OSG
> > > > > "engagement" VO using this Swift command, which returns
> > the list as a
> > > > > sites.xml file:
> > > > > swift-osg-ress-site-catalog --engage-verified
> > > > > That command also has options for getting sites from
> > other VOs
> > > > > swift-osg-ress-site-catalog --vo=osg
> > > > > On 6/26/09 2:04 PM, Melinda Chin wrote:
> > > > > > Here's what I think is a simple question but can't
> > find the answer to?
> > > > > > Where can I find a list of all the osg sites?
> > > > > > Thank you,
> > > > > > Melinda Chin
> > > > > > _______________________________________________
> > > > > > Swift-user mailing list
> > > > > > Swift-user at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090626/516fa90b/attachment.html>
More information about the Swift-user
