[swift-user] List of OSG sites
Mihael Hategan hategan at mcs.anl.gov
Fri Jun 26 16:34:31 CDT 2009
On Fri, 2009-06-26 at 16:22 -0500, Glen Hocky wrote:
> By the way, in reference to my previous e-mail. the result of my
> condor status is:
Yep, this means it's working, but there is no condor pool on tp.
Erin, try this:
source /autonfs/software/linux-rhel4-x86_64/osg-client-1.0.0-r1/setup.sh
Then swift-osg...
> condor_status
> CEDAR:6001:Failed to connect to <128.135.125.117:9618>
> Error: Couldn't contact the condor_collector on
> tp-login2.ci.uchicago.edu.
> Extra Info: the condor_collector is a process that runs on the
> central
> manager of your Condor pool and collects the status of all the
> machines and
> jobs in the Condor pool. The condor_collector might not be running, it
> might
> be refusing to communicate with you, there might be a network problem,
> or
> there may be some other problem. Check with your system administrator
> to fix
> this problem.
> If you are the system administrator, check that the condor_collector
> is
> running on tp-login2.ci.uchicago.edu, check the HOSTALLOW
> configuration in
> your condor_config, and check the MasterLog and CollectorLog files in
> your
> log directory for possible clues as to why the condor_collector is
> not
> responding. Also see the Troubleshooting section of the manual.
> which is different from yours. try putting @osg and +osg-client before
> @default
> On Fri, Jun 26, 2009 at 3:59 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
>         Doesn't work.
>         My .soft:
>         @default
>         @globus-4
>         +java-sun
>         +torque
>         +maui
>         +condor
>         @osg
>         +osg-client
>         [hategan at tp-login2 ~]$ condor_status
>         Neither the environment variable CONDOR_CONFIG,
>         /etc/condor/, nor ~condor/ contain a condor_config source.
>         Either set CONDOR_CONFIG to point to a valid config source,
>         or put a "condor_config" file in /etc/condor or ~condor/
>         Exiting.
>         On Fri, 2009-06-26 at 15:41 -0500, Michael Wilde wrote:
>         > If you added your swift/bin directory to your path manually,
>         when you
>         > run resoft you may loose that and need to do it again.
>         > On 6/26/09 3:33 PM, Hodgess, Erin wrote:
>         > > This is getting weird:
>         > > [erin at tp-login2 ~]$  swift-osg-ress-site-catalog
>         --engage-verified
>         > > -bash: swift-osg-ress-site-catalog: command not found
>         > > Erin M. Hodgess, PhD
>         > > Associate Professor
>         > > Department of Computer and Mathematical Sciences
>         > > University of Houston - Downtown
>         > > mailto: hodgesse at uhd.edu
>         > > -----Original Message-----
>         > > From: hockyg at gmail.com on behalf of Glen Hocky
>         > > Sent: Fri 6/26/2009 3:24 PM
>         > > To: Hodgess, Erin
>         > > Cc: Michael Wilde; Melinda Chin; Swift User Discussion
>         List
>         > > Subject: Re: [swift-user] List of OSG sites
>         > > It's likely this error can be fixed by the same thing Zhao
>         did to get condor
>         > > working last week (since the command works for me). Try
>         putting @osg and
>         > > +osg-client into your ~/.soft file and then resetting up
>         by either logging
>         > > back in or typing "resoft;source ~/.bashrc"
>         > > for reference, here is my ~/.soft file
>         > > @python-2.5
>         > > +java-sun
>         > > +osg-client
>         > > +maui
>         > > +torque
>         > > +R
>         > > +matlab-7.7
>         > > +apache-ant
>         > > +gx-map
>         > > @osg
>         > > @default
>         > > @globus-4
>         > > On Fri, Jun 26, 2009 at 3:20 PM, Hodgess, Erin
>         <HodgessE at uhd.edu> wrote:
>         > >  >  I'm having trouble with the
>         swift-osg-ress-site-catalog command:
>         > >  > [erin at tp-login2 swift]$  swift-osg-ress-site-catalog
>         --engage-verified
>         source.
>         source,
>         ~condor/
>         > >  > Exiting.
>         > >  > <config>
>         > >  > </config>
>         > >  > Any help is much appreciated.
>         > >  > Thanks,
>         > >  > Erin
>         > >  > Associate Professor
>         > >  > From: swift-user-bounces at ci.uchicago.edu on behalf of
>         Michael Wilde
>         > >  > Sent: Fri 6/26/2009 2:14 PM
>         > >  > To: Melinda Chin
>         > >  > Cc: Swift User Discussion List
>         > >  >  From a practical point of view, you can get the sites
>         in the OSG
>         > >  > "engagement" VO using this Swift command, which returns
>         the list as a
>         > >  > sites.xml file:
>         > >  >    swift-osg-ress-site-catalog --engage-verified
>         > >  > That command also has options for getting sites from
>         other VOs
>         > >  >    swift-osg-ress-site-catalog --vo=osg
>         > >  > On 6/26/09 2:04 PM, Melinda Chin wrote:
>         > >  > > Here's what I think is a simple question but can't
>         find the answer to?
>         > >  > > Where can I find a list of all the osg sites?
>         > >  > > Thank you,
>         > >  > > Melinda Chin
>         > >  > > _______________________________________________
>         > >  > > Swift-user mailing list
>         > >  > > Swift-user at ci.uchicago.edu
>         http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
