[swift-user] List of OSG sites
    Glen Hocky
    hockyg at uchicago.edu
    Fri Jun 26 15:24:46 CDT 2009
It's likely this error can be fixed by the same thing Zhao did to get condor
working last week (since the command works for me). Try putting @osg and
+osg-client into your ~/.soft file and then resetting up by either logging
back in or typing "resoft;source ~/.bashrc"
for reference, here is my ~/.soft file
@python-2.5
+java-sun
+osg-client
+maui
+torque
+R
+matlab-7.7
+apache-ant
+gx-map
@osg
@default
@globus-4
On Fri, Jun 26, 2009 at 3:20 PM, Hodgess, Erin <HodgessE at uhd.edu> wrote:
>  I'm having trouble with the swift-osg-ress-site-catalog command:
> [erin at tp-login2 swift]$  swift-osg-ress-site-catalog --engage-verified
> Neither the environment variable CONDOR_CONFIG,
> /etc/condor/, nor ~condor/ contain a condor_config source.
> Either set CONDOR_CONFIG to point to a valid config source,
> or put a "condor_config" file in /etc/condor or ~condor/
> Exiting.
> <config>
> </config>
> Any help is much appreciated.
> Thanks,
> Erin
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
> -----Original Message-----
> From: swift-user-bounces at ci.uchicago.edu on behalf of Michael Wilde
> Sent: Fri 6/26/2009 2:14 PM
> To: Melinda Chin
> Cc: Swift User Discussion List
> Subject: Re: [swift-user] List of OSG sites
>  From a practical point of view, you can get the sites in the OSG
> "engagement" VO using this Swift command, which returns the list as a
> sites.xml file:
> That command also has options for getting sites from other VOs
>    swift-osg-ress-site-catalog --vo=osg
> On 6/26/09 2:04 PM, Melinda Chin wrote:
> > Here's what I think is a simple question but can't find the answer to?
> > Where can I find a list of all the osg sites?
> > Thank you,
> > Melinda Chin
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090626/b25ad63b/attachment.html>
More information about the Swift-user
