[Swift-user] multiple files for each app call
Melinda Chin
me.melly at gmail.com
Mon Jun 15 11:41:19 CDT 2009
I was trying to do the t.swift tutorial again and I keep getting stuck on
this error. What does it mean to not be able to find a valid host? How do
I remedy this? And another question on the side what's the difference
between swift-user at ci.uchicago.edu and swift-user-owner at ci.uchicago.edu.
For help we can send to both? or usually just swift-user?
*THIS IS WHAT t.swift LOOKS LIKE:*
[mchin at tp-login2 swift]$ cat t.swift
type messagefile;
(messagefile t) greeting (string s) {
app{
echo s stdout = @filename(t);
(messagefile t) capitalise (messagefile f) {
app {
translate "[a-z]" "[A-Z]" stdin = @filename(f) stdout =
@filename(t);
messagefile outfile <"greeting.txt">;
messagefile cfile <"capitalised.txt">;
outfile = greeting("hello from Swift");
cfile = capitalise(outfile);
*THIS IS WHAT tc.data LOOKS LIKE:*
[mchin at tp-login2 swift]$ cat tc.data
#This is the transformation catalog.
#It comes pre-configured with a number of simple transformations with
#paths that are likely to work on a linux box. However, on some systems,
#the paths to these executables will be different (for example, sometimes
#some of these programs are found in /usr/bin rather than in /bin)
#NOTE WELL: fields in this file must be separated by tabs, not spaces; and
#there must be no trailing whitespace at the end of each line.
# sitename transformation path INSTALLED platform profiles
localhost echo /bin/echo INSTALLED
INTEL32::LINUX null
localhost cat /bin/cat INSTALLED
INTEL32::LINUX null
localhost ls /bin/ls INSTALLED
INTEL32::LINUX null
localhost grep /bin/grep INSTALLED
INTEL32::LINUX null
localhost sort /bin/sort INSTALLED
INTEL32::LINUX null
localhost paste /bin/paste INSTALLED
INTEL32::LINUX null
localhost translate /usr/bin/tr INSTALLED
INTEL32::LINUX null
*THIS IS THE ERROR MESSAGE:*
[mchin at tp-login2 swift]$ swift t.swift
Swift svn swift-r2950 cog-r2406
RunID: 20090615-1125-6z1ehvf8
Progress:
Progress: Initializing site shared directory:1
Execution failed:
Could not find any valid host for task "Task(type=UNKNOWN,
identity=urn:cog-1245083114852)" with constraints
{filenames=[Ljava.lang.String;@1f0a76e, trfqn=translate,
filecache=org.griphyn.vdl.karajan.lib.cache.CacheMapAdapter at 1f0a797,
tr=translate}
Thank you for your help,
Melinda Chin
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090615/8d8d408b/attachment.html>
More information about the Swift-user
