[Swift-user] running on teraport
Michael Wilde
wilde at mcs.anl.gov
Sat Jun 6 21:31:32 CDT 2009
Youre getting an error when Swift tries to start coasters, because you
dont have a valid Grid proxy.
You need to do a grid-proxy-init before you run with coasters, even if
your are using them with jobmanager=local:pbs, because coasters uses
grid security for its communication channels.
These errors were in your coaster bootstrap log:
java.lang.RuntimeException: Failed to register service
Caused by:
org.globus.cog.karajan.workflow.service.channels.ChannelException:
Failed to start channel GSSCChannel-https:
//128.135.125.117:50000(1)
Caused by: org.globus.gsi.GlobusCredentialException: [JGLOBUS-10]
Expired credentials (DC=org,DC=doegrids,OU=People,...
in your $HOME.
For initial tests, its usually simpler to test using the local pbs
provider instead of coasters:
<execution provider="pbs" url="none" />
Once that works, try coasters.
- Mike
On 6/6/09 8:47 PM, Hodgess, Erin wrote:
> Hello again.
> I'm running on the teraport, and received all of these messages.
> [erin at tp-login2 bin]$ swift -tc.file tc.data -sites.file sites1.xml
> fun1.swift
> Swift svn swift-r2950 cog-r2406
> RunID: 20090606-2016-8bxotcug
> Progress:
> Progress: Selecting site:9 Initializing site shared directory:1
> Progress: Selecting site:9 Stage in:1
> Progress: Selecting site:8 Submitting:1 Submitted:1
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/a
> on teraport
> Progress: Selecting site:7 Submitting:1 Submitted:1 Failed but can
> retry:1
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/9
> on teraport
> Progress: Selecting site:7 Submitted:1 Failed but can retry:2
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/c
> on teraport
> Progress: Selecting site:6 Submitted:1 Failed but can retry:3
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/e
> on teraport
> Progress: Selecting site:6 Failed but can retry:4
> Progress: Selecting site:5 Stage in:1 Failed but can retry:4
> Progress: Selecting site:5 Submitted:1 Failed but can retry:4
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/h
> on teraport
> Progress: Selecting site:5 Failed but can retry:5
> Progress: Selecting site:4 Stage in:1 Failed but can retry:5
> Progress: Selecting site:4 Submitted:1 Failed but can retry:5
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/j
> on teraport
> Progress: Selecting site:4 Failed but can retry:6
> Progress: Selecting site:3 Stage in:1 Failed but can retry:6
> Progress: Selecting site:3 Submitted:1 Failed but can retry:6
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/l
> on teraport
> Progress: Selecting site:3 Failed but can retry:7
> Progress: Selecting site:2 Stage in:1 Failed but can retry:7
> Progress: Selecting site:2 Submitted:1 Failed but can retry:7
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/n
> on teraport
> Progress: Selecting site:2 Failed but can retry:8
> Progress: Selecting site:1 Stage in:1 Failed but can retry:8
> Progress: Selecting site:1 Submitted:1 Failed but can retry:8
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/p
> on teraport
> Progress: Selecting site:1 Failed but can retry:9
> Progress: Stage in:1 Failed but can retry:9
> Progress: Submitted:1 Failed but can retry:9
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/r
> on teraport
> Progress: Failed but can retry:10
> Progress: Submitting:1 Failed but can retry:9
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/t
> on teraport
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/v
> on teraport
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/y
> on teraport
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/0
> on teraport
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/2
> on teraport
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/4
> on teraport
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/6
> on teraport
> Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/8
> on teraport
> on teraport
> on teraport
> on teraport
> Execution failed:
> Exception in RInvoke:
> Arguments: [ttest1.R, 1, fun.dat]
> Host: teraport
> Directory: fun1-20090606-2016-8bxotcug/jobs/e/RInvoke-enuqrvbj
> stderr.txt:
> stdout.txt:
> Caused by:
> Could not submit job
> Caused by:
> Could not start coaster service
> Caused by:
> Task ended before registration was received.
> STDOUT:
> STDERR: which: no gmd5sum in
> (/soft/java-1.6.0_11-sun-r1/bin:/soft/java-1.6.0_11-sun-r1/jre/bin:/soft/apache-ant-1.7.1-r1/bin:/software/common/gx-map-0.5.3.3-r1/bin:/soft/condor-7.0.5-r1/bin:/soft/globus-4.2.1-r1/bin:/soft/globus-4.2.1-r1/sbin:/usr/kerberos/bin:/bin:/usr/bin:/usr/X11R6/bin:/usr/local/bin:/software/common/softenv-1.6.0-r1/bin:/home/erin/bin/linux-rhel5-x86_64:/home/erin/bin:/soft/torque-2.3.6-r1/bin:/soft/maui-3.2.6p21-r1/bin:/soft/maui-3.2.6p21-r1/sbin:/soft/matlab-7.7-r1/bin:/soft/osg-client-1.0.0-r1/lcg/bin:/soft/osg-client-1.0.0-r1/srm-client-lbnl/bin:/soft/osg-client-1.0.0-r1/srm-client-fermi/sbin:/soft/osg-client-1.0.0-r1/srm-client-fermi/bin:/soft/osg-client-1.0.0-r1/curl/bin:/soft/osg-client-1.0.0-r1/wget/bin:/soft/osg-client-1.0.0-r1/cert-scripts/bin:/soft/osg-client-1.0.0-r1/glite/sbin:/soft/osg-client-1.0.0-r1/glite/bin:/soft/osg-client-1.0.0-r1/pyglobus-url-copy/bin:/soft/osg-client-1.0.0-r1/pegasus/bin:/soft/osg-client-1.0.0-r1/ant/bin:/soft/osg-client-1.0.0-r1/gpt/sbin:/so
ft/osg-client-1.0.0-r1/globus/bin:/soft/osg-client-1.0.0-r1/globus/sbin:/soft/osg-client-1.0.0-r1/jdk1.5/bin:/soft/osg-client-1.0.0-r1/condor/sbin:/soft/osg-client-1.0.0-r1/condor/bin:/soft/osg-client-1.0.0-r1/logrotate/sbin:/software/common/pacman-3.26-r1/bin:/soft/osg-client-1.0.0-r1/vdt/sbin:/soft/osg-client-1.0.0-r1/vdt/bin:/home/grog/bin/linux-rhel4-ia32:/home/grog/bin:/sw/bin:/sbin:/usr/sbin:/home/erin/bin:/home/erin/cog/modules/swift/dist/swift-svn/bin)
> Caused by:
> Job failed with an exit code of 1
> Cleaning up...
> Done
> So anyhow, it doesn't like something.
> Here is the tc.data file:
> erin at tp-login2 bin]$ cat tc.data
> #NOTE WELL: fields in this file must be separated by tabs, not spaces
> # and there must be no trailing whitespace at the end of each
> line.
> # sitename app pathname (ignored) (ignored)
> profiles
> localhost echo /bin/echo INSTALLED INTEL32::LINUX null
> teraport echo /bin/echo INSTALLED INTEL32::LINUX null
> localhost translate /usr/bin/tr INSTALLED
> INTEL32::LINUX null
> localhost R /home/erin/R-2.9.0/bin/R INSTALLED
> INTEL32::LINUX null
> localhost wc /usr/bin/wc INSTALLED INTEL32::LINUX null
> localhost convert /usr/bin/convert INSTALLED
> INTEL32::LINUX null
> localhost RInvoke /home/erin/R-2.9.0/bin/RInvoke.sh
> teraport RInvoke /home/erin/R-2.9.0/bin/RInvoke.sh
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
