[Swift-user] running on teraport
    Hodgess, Erin
    HodgessE at uhd.edu
    Sat Jun  6 20:47:23 CDT 2009
Hello again.
I'm running on the teraport, and received all of these messages.
[erin at tp-login2 bin]$ swift -tc.file tc.data -sites.file sites1.xml fun1.swift
Swift svn swift-r2950 cog-r2406
RunID: 20090606-2016-8bxotcug
Progress:
Progress:  Selecting site:9  Initializing site shared directory:1
Progress:  Selecting site:9  Stage in:1
Progress:  Selecting site:8  Submitting:1  Submitted:1
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/a on teraport
Progress:  Selecting site:7  Submitting:1  Submitted:1 Failed but can retry:1
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/9 on teraport
Progress:  Selecting site:7  Submitted:1 Failed but can retry:2
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/c on teraport
Progress:  Selecting site:6  Submitted:1 Failed but can retry:3
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/e on teraport
Progress:  Selecting site:6 Failed but can retry:4
Progress:  Selecting site:5  Stage in:1 Failed but can retry:4
Progress:  Selecting site:5  Submitted:1 Failed but can retry:4
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/h on teraport
Progress:  Selecting site:5 Failed but can retry:5
Progress:  Selecting site:4  Stage in:1 Failed but can retry:5
Progress:  Selecting site:4  Submitted:1 Failed but can retry:5
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/j on teraport
Progress:  Selecting site:4 Failed but can retry:6
Progress:  Selecting site:3  Stage in:1 Failed but can retry:6
Progress:  Selecting site:3  Submitted:1 Failed but can retry:6
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/l on teraport
Progress:  Selecting site:3 Failed but can retry:7
Progress:  Selecting site:2  Stage in:1 Failed but can retry:7
Progress:  Selecting site:2  Submitted:1 Failed but can retry:7
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/n on teraport
Progress:  Selecting site:2 Failed but can retry:8
Progress:  Selecting site:1  Stage in:1 Failed but can retry:8
Progress:  Selecting site:1  Submitted:1 Failed but can retry:8
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/p on teraport
Progress:  Selecting site:1 Failed but can retry:9
Progress:  Stage in:1 Failed but can retry:9
Progress:  Submitted:1 Failed but can retry:9
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/r on teraport
Progress: Failed but can retry:10
Progress:  Submitting:1 Failed but can retry:9
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/t on teraport
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/v on teraport
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/y on teraport
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/0 on teraport
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/2 on teraport
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/4 on teraport
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/6 on teraport
Failed to transfer wrapper log from fun1-20090606-2016-8bxotcug/info/8 on teraport
Execution failed:
	Exception in RInvoke:
Arguments: [ttest1.R, 1, fun.dat]
Host: teraport
Directory: fun1-20090606-2016-8bxotcug/jobs/e/RInvoke-enuqrvbj
stderr.txt:
stdout.txt:
Caused by:
	Could not submit job
Caused by:
	Could not start coaster service
Caused by:
	Task ended before registration was received.
STDOUT:
STDERR: which: no gmd5sum in (/soft/java-1.6.0_11-sun-r1/bin:/soft/java-1.6.0_11-sun-r1/jre/bin:/soft/apache-ant-1.7.1-r1/bin:/software/common/gx-map-0.5.3.3-r1/bin:/soft/condor-7.0.5-r1/bin:/soft/globus-4.2.1-r1/bin:/soft/globus-4.2.1-r1/sbin:/usr/kerberos/bin:/bin:/usr/bin:/usr/X11R6/bin:/usr/local/bin:/software/common/softenv-1.6.0-r1/bin:/home/erin/bin/linux-rhel5-x86_64:/home/erin/bin:/soft/torque-2.3.6-r1/bin:/soft/maui-3.2.6p21-r1/bin:/soft/maui-3.2.6p21-r1/sbin:/soft/matlab-7.7-r1/bin:/soft/osg-client-1.0.0-r1/lcg/bin:/soft/osg-client-1.0.0-r1/srm-client-lbnl/bin:/soft/osg-client-1.0.0-r1/srm-client-fermi/sbin:/soft/osg-client-1.0.0-r1/srm-client-fermi/bin:/soft/osg-client-1.0.0-r1/curl/bin:/soft/osg-client-1.0.0-r1/wget/bin:/soft/osg-client-1.0.0-r1/cert-scripts/bin:/soft/osg-client-1.0.0-r1/glite/sbin:/soft/osg-client-1.0.0-r1/glite/bin:/soft/osg-client-1.0.0-r1/pyglobus-url-copy/bin:/soft/osg-client-1.0.0-r1/pegasus/bin:/soft/osg-client-1.0.0-r1/ant/bin:/soft/osg-client-1.0.0-r1/gpt/sbin:/soft/osg-client-1.0.0-r1/globus/bin:/soft/osg-client-1.0.0-r1/globus/sbin:/soft/osg-client-1.0.0-r1/jdk1.5/bin:/soft/osg-client-1.0.0-r1/condor/sbin:/soft/osg-client-1.0.0-r1/condor/bin:/soft/osg-client-1.0.0-r1/logrotate/sbin:/software/common/pacman-3.26-r1/bin:/soft/osg-client-1.0.0-r1/vdt/sbin:/soft/osg-client-1.0.0-r1/vdt/bin:/home/grog/bin/linux-rhel4-ia32:/home/grog/bin:/sw/bin:/sbin:/usr/sbin:/home/erin/bin:/home/erin/cog/modules/swift/dist/swift-svn/bin)
Caused by:
	Job failed with an exit code of 1
Cleaning up...
 Done
So anyhow, it doesn't like something.
Here is the tc.data file:
erin at tp-login2 bin]$ cat tc.data
#NOTE WELL: fields in this file must be separated by tabs, not spaces
#           and there must be no trailing whitespace at the end of each line.
# sitename      app     pathname        (ignored)       (ignored)       profiles
localhost       echo    /bin/echo       INSTALLED       INTEL32::LINUX  null
teraport        echo    /bin/echo       INSTALLED       INTEL32::LINUX  null
localhost	translate	/usr/bin/tr	INSTALLED	INTEL32::LINUX	null
localhost	R	/home/erin/R-2.9.0/bin/R	INSTALLED	INTEL32::LINUX	null
localhost       wc	/usr/bin/wc     INSTALLED       INTEL32::LINUX	null
localhost       convert	/usr/bin/convert	INSTALLED	INTEL32::LINUX	null
localhost	RInvoke	/home/erin/R-2.9.0/bin/RInvoke.sh	INSTALLED	INTEL32::LINUX	null
teraport	RInvoke /home/erin/R-2.9.0/bin/RInvoke.sh       INSTALLED	INTEL32::LINUX  null
Erin M. Hodgess, PhD
Associate Professor
Department of Computer and Mathematical Sciences
University of Houston - Downtown
mailto: hodgesse at uhd.edu
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090606/8b0e024c/attachment.html>
More information about the Swift-user
