[Swift-user] doesn't create output file
Michael Wilde
wilde at mcs.anl.gov
Wed Jun 3 23:03:48 CDT 2009
Erin,
Looking at your R script, it seems like it ran OK (from e1.in.Rout) but
there is no R statement in the R input that writes the output object xz
to the data file xy.out where your swift scriptis expecting to find it.
Also, in future email questions, send the name of the directory that you
ran from - I had to hunt around a bit in /home/erin to find it.
- Mike
R output was:
more e1.in.Rout
R version 2.5.1 (2007-06-27)
Copyright (C) 2007 The R Foundation for Statistical Computing
ISBN 3-900051-07-0
R is free software and comes with ABSOLUTELY NO WARRANTY.
You are welcome to redistribute it under certain conditions.
Type 'license()' or 'licence()' for distribution details.
Natural language support but running in an English locale
R is a collaborative project with many contributors.
Type 'contributors()' for more information and
'citation()' on how to cite R or R packages in publications.
Type 'demo()' for some demos, 'help()' for on-line help, or
'help.start()' for an HTML browser interface to help.
Type 'q()' to quit R.
> allinputs <- Sys.getenv("R_SWIFT_ARGS")
> print(allinputs)
R_SWIFT_ARGS
"xx.dat 25 4"
> inputfilename <- noquote(strsplit(allinputs," ")[[1]][1])
> start_num <- as.numeric(noquote(strsplit(allinputs," ")[[1]][2]))
> n1 <- as.numeric(noquote(strsplit(allinputs," ")[[1]][3]))
> print(n1)
[1] 4
> xy <- matrix(scan(inputfilename),byrow=TRUE,ncol=5)
Read 50 items
> xz <- apply(xy,2,mean)
> xz
[1] 0.2526954 -0.7243118 0.2969102 -0.2283567 -0.2468762
> proc.time()
user system elapsed
0.775 0.033 0.797
^^^^ No statement to write xy into xy.out (or to write out any other
result, like xz).
On 6/3/09 10:03 PM, Hodgess, Erin wrote:
> Hi again!
> I'm looking at some of Sarah's really cool stuff and trying to reproduce
> test versions.
> Here is the swift file:
> [erin at tp-login2 bin]$ cat test1.swift
> type file{}
> #--- trying to learn from Sarah's cool stuff
> type file{}
> app (file simResult) simScript (file scriptFile, file inputFile,
> int iter,int tval){
> RInvoke @filename(scriptFile) @filename(inputFile) iter tval;
> file script<"e1.in">;
> file inputData<"xx.dat">;
> file simResult<"xy.out">;
> int iter = 25;
> int tval = 4;
> simResult=simScript(script,inputData,iter,tval);
> And here is the result:
> [erin at tp-login2 bin]$ swift -tc.file tc.data test1.swift
> Swift svn swift-r2950 cog-r2406
> RunID: 20090603-2200-krmao849
> Progress:
> Progress: Checking status:1
> Execution failed:
> Exception in RInvoke:
> Arguments: [e1.in, xx.dat, 25, 4]
> Host: localhost
> Directory: test1-20090603-2200-krmao849/jobs/k/RInvoke-k4l6zqbj
> stderr.txt:
> stdout.txt:
> Caused by:
> The following output files were not created by the application:
> xy.out
> The tc.data is here:
> [erin at tp-login2 bin]$ cat tc.data
> #NOTE WELL: fields in this file must be separated by tabs, not spaces
> # and there must be no trailing whitespace at the end of each
> line.
> # sitename app pathname (ignored) (ignored)
> profiles
> localhost echo /bin/echo INSTALLED INTEL32::LINUX null
> teraport echo /bin/echo INSTALLED INTEL32::LINUX null
> localhost translate /usr/bin/tr INSTALLED
> INTEL32::LINUX null
> localhost R /home/erin/R-2.9.0/bin/R INSTALLED
> INTEL32::LINUX null
> localhost wc /usr/bin/wc INSTALLED INTEL32::LINUX null
> localhost convert /usr/bin/convert INSTALLED
> INTEL32::LINUX null
> localhost RInvoke /home/erin/R-2.9.0/bin/RInvoke.sh
> Any suggestions most appreciated.
> Erin
> Erin M. Hodgess, PhD
> Associate Professor
> Department of Computer and Mathematical Sciences
> University of Houston - Downtown
> mailto: hodgesse at uhd.edu
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
