[Swift-user] doesn't create output file
    Hodgess, Erin
    HodgessE at uhd.edu
    Wed Jun  3 22:03:39 CDT 2009
Hi again!
I'm looking at some of Sarah's really cool stuff and trying to reproduce test versions.
Here is the swift file:
[erin at tp-login2 bin]$ cat test1.swift
type file{}
	#--- trying to learn from Sarah's cool stuff
type file{}
	app (file simResult) simScript (file scriptFile, file inputFile, int iter,int tval){
	    RInvoke  @filename(scriptFile) @filename(inputFile) iter tval;
	    file script<"e1.in">;
	    file inputData<"xx.dat">;
	    file simResult<"xy.out">;
	int iter = 25;
	int tval = 4;
            simResult=simScript(script,inputData,iter,tval);
And here is the result:
[erin at tp-login2 bin]$ swift -tc.file tc.data test1.swift
Swift svn swift-r2950 cog-r2406
RunID: 20090603-2200-krmao849
Progress:
Progress:  Checking status:1
Execution failed:
	Exception in RInvoke:
Arguments: [e1.in, xx.dat, 25, 4]
Host: localhost
Directory: test1-20090603-2200-krmao849/jobs/k/RInvoke-k4l6zqbj
stderr.txt:
stdout.txt:
Caused by:
	The following output files were not created by the application: xy.out
The tc.data is here:
[erin at tp-login2 bin]$ cat tc.data
#NOTE WELL: fields in this file must be separated by tabs, not spaces
#           and there must be no trailing whitespace at the end of each line.
# sitename      app     pathname        (ignored)       (ignored)       profiles
localhost       echo    /bin/echo       INSTALLED       INTEL32::LINUX  null
teraport        echo    /bin/echo       INSTALLED       INTEL32::LINUX  null
localhost	translate	/usr/bin/tr	INSTALLED	INTEL32::LINUX	null
localhost	R	/home/erin/R-2.9.0/bin/R	INSTALLED	INTEL32::LINUX	null
localhost       wc	/usr/bin/wc     INSTALLED       INTEL32::LINUX	null
localhost       convert	/usr/bin/convert	INSTALLED	INTEL32::LINUX	null
localhost	RInvoke	/home/erin/R-2.9.0/bin/RInvoke.sh	INSTALLED	INTEL32::LINUX	null
Any suggestions most appreciated.
Erin
Erin M. Hodgess, PhD
Associate Professor
Department of Computer and Mathematical Sciences
University of Houston - Downtown
mailto: hodgesse at uhd.edu
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090603/3101ff49/attachment.html>
More information about the Swift-user
