[Swift-user] mixing gram execution and local filesystem providers
    Allan Espinosa
    aespinosa at cs.uchicago.edu
    Mon Feb  2 14:04:22 CST 2009
I see.  so when i submit from teraport, the Java environment seems to
be detected smoothly over coasters.
Thanks Ben!
-Allan
On Mon, Feb 2, 2009 at 2:01 PM, Ben Clifford <benc at hawaga.org.uk> wrote:
> embedded deep in that log file is:
>> STDOUT: Could not find a valid java executable
> Have a read over Mike (Wilde)'s emails over the past few days about
> running on teraport and getting Java paths working - there are some notes
> in there.
> It looks like you're getting different paths when you submit through the
> pbs provider vs submitting through GRAM2 - with direct PBS, likely giving
> you Java and with GRAM, not giving you Java.
> This is something that needs some user interface improvements on, so this
> will all be quite rough at the moment, but your experiences are pretty
> useful for helping iron this out.
> It looks like that coaster error needs to find its way into console output
> rather than being deep in the log files.
> The way in which Java is found needs some more configurability too...
More information about the Swift-user
