[Swift-user] Re: [Swift-devel] How to the maximum number of concurrent jobs allowed on a site to a fixed size?
Allan Espinosa
aespinosa at cs.uchicago.edu
Thu Aug 6 15:30:24 CDT 2009
hi yi,
in swift.properites file you set
foreach.max.threads=1024
to
foreach.max.threads=N
where N is the max number concurrent jobs you want per swift session.
Also when you set score to be ridicuosly high (ie 10000) you always
get the maximum theoretical number of jobs you want based on the
throttling parameters.
-Allan
2009/8/6 Yi Zhu <yizhu at cs.uchicago.edu>:
> Hi, all
> As we've already know, Swift dynamically change the maximum number of
> concurrent jobs allowed on a site based on the performance history of that
> site. According to swift Document: Each site is assigned a score (initially
> 1), which can increase or decrease based on whether the site yields
> successful or faulty job runs. The score for a site can take values in the
> (0.1, 100) interval. The number of allowed jobs is calculated using the
> following formula:
> 2 + score*throttle.score.job.factor
> We can change the throttle.score.job.factor in sites.xml or swift.properties
> files, but since the "score" value can be increased/decreased during the
> execution, It seems that we can not really set the maximum number of
> concurrent jobs allowed on a site to a fixed number. Anyone have any idea of
> that?
> Many Thanks.
More information about the Swift-user
