[Swift-user] job waiting
    Yue, Chen - BMD
    yuechen at bsd.uchicago.edu
    Sat Apr 18 18:20:43 CDT 2009
Hi Ben,
Thanks for answering my question. This phenomena occur after half an hour of execution. If all the jobs finish execution at original speed, it would probably take not more than 40 min. How the system figure out that some jobs will take more than 1 hour? Should I request more time when I execute "grid-proxy-init"?
I did not change the default throttles. How much is more appropriate? The total number of jobs in my application typically run between 4000 and 30000 and typically each job can be finished within a couple of minutes.
Thanks!
Chen, Yue
Sent: Sat 4/18/2009 5:05 PM
To: Yue, Chen - BMD
Cc: swift user
Subject: Re: [Swift-user] job waiting
actually, I see you're using coasters on NCSA, so the actual numbers for
walltimes being submitted into NCSA's queueing system will be a little
strange. But my first question, that some jobs taking around an hour still
stands.
Also I notice a large number of jobs being submitted at the start of your
run - have you adjusted the default throttles on your swift installation
to some larger value?
This email is intended only for the use of the individual or entity to which it is addressed and may contain information that is privileged and confidential. If the reader of this email message is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is prohibited. If you have received this email in error, please notify the sender and destroy/delete all copies of the transmittal. Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090418/bdcccda7/attachment.html>
More information about the Swift-user
