[Swift-user] possible coasters problem
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Apr  1 10:28:48 CDT 2009
I think it was run on cog 2349, swift 2787.
com$ svn info cog
Path: cog
URL: https://cogkit.svn.sourceforge.net/svnroot/cogkit/trunk/current/src/cog
Repository Root: https://cogkit.svn.sourceforge.net/svnroot/cogkit
Repository UUID: 5b74d2a0-fa0e-0410-85ed-ffba77ec0bde
Revision: 2349
Node Kind: directory
Schedule: normal
Last Changed Author: hategan
Last Changed Rev: 2349
Last Changed Date: 2009-03-29 14:58:40 -0500 (Sun, 29 Mar 2009)
com$ svn info cog/modules/swift
Path: cog/modules/swift
URL: https://svn.ci.uchicago.edu/svn/vdl2/trunk
Repository Root: https://svn.ci.uchicago.edu/svn/vdl2
Repository UUID: e2bb083e-7f23-0410-b3a8-8253ac9ef6d8
Revision: 2788
Schedule: normal
Last Changed Rev: 2787
Last Changed Date: 2009-03-30 19:31:33 -0500 (Mon, 30 Mar 2009)
com$
On 4/1/09 10:22 AM, Mihael Hategan wrote:
> On Tue, 2009-03-31 at 17:40 -0500, Glen Hocky wrote:
>> Hi Guys,
>> Do you think this is a problem with coasters or just the way i'm using it...
> It's a problem with coasters.
> What version of cog/swift is this?
>> Thanks,
>> Glen
>>> Exception in runoops:
>>> Arguments: [input/fasta/T1ubq.fasta,
>>> teraportoutdir.100/T1ubq/T1ubq.ST50.TU200.0000.secseq,
>>> input/native/T1ubq.pdb,
>>> teraportoutdir.100/T1ubq//ST50.TU200/0000/00/06/T1ubq.ST50.TU200.0000.0006.pdt,
>>> teraportoutdir.100/T1ubq//ST50.TU200/0000/00/06/T1ubq.ST50.TU200.0000.0006.rmsd,
>>> 6, DEFAULT_INIT_TEMP_=_50, TEMP_UPDATE_INTERVAL_=_200,
>>> MAX_NUMBER_OF_ANNEALING_STEPS_=_0, KILL_TIME_=_55]
>>> Host: teraport
>>> Directory: oops-20090331-1701-fpuie7be/jobs/d/runoops-dsmccq8j
>>> stderr.txt:
>>> stdout.txt:
>>> Caused by:
>>> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
>>> java.lang.IllegalArgumentException: No worker with id=1956306968
>>> at
>>> org.globus.cog.abstraction.coaster.service.job.manager.CoasterTaskHandler.submit(CoasterTaskHandler.java:85)
>>> at
>>> org.globus.cog.abstraction.coaster.service.job.manager.CoasterQueueProcessor.run(CoasterQueueProcessor.java:71)
>>> Caused by: java.lang.IllegalArgumentException: No worker with
>>> id=1956306968
>>> at
>>> org.globus.cog.abstraction.coaster.service.job.manager.WorkerManager.getChannelContext(WorkerManager.java:483)
>>> at
>>> org.globus.cog.abstraction.coaster.service.job.manager.CoasterTaskHandler.submit(CoasterTaskHandler.java:78)
>>> ... 1 more
>>> Cleaning up...
>>> Shutting down service at https://128.135.125.118:55513
>>> Got channel MetaChannel: 22129174 -> GSSSChannel-null(1)
>>> - Done
>>> Command exited with non-zero status 2
>>> real 1628.27
>>> user 169.87
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
