[Swift-user] possible coasters problem
Mihael Hategan hategan at mcs.anl.gov
Wed Apr 1 10:22:55 CDT 2009
On Tue, 2009-03-31 at 17:40 -0500, Glen Hocky wrote:
> Hi Guys,
> Do you think this is a problem with coasters or just the way i'm using it...
It's a problem with coasters.
What version of cog/swift is this?
> Thanks,
> Glen
> > Exception in runoops:
> > Arguments: [input/fasta/T1ubq.fasta,
> > teraportoutdir.100/T1ubq/T1ubq.ST50.TU200.0000.secseq,
> > input/native/T1ubq.pdb,
> > teraportoutdir.100/T1ubq//ST50.TU200/0000/00/06/T1ubq.ST50.TU200.0000.0006.pdt,
> > teraportoutdir.100/T1ubq//ST50.TU200/0000/00/06/T1ubq.ST50.TU200.0000.0006.rmsd,
> > 6, DEFAULT_INIT_TEMP_=_50, TEMP_UPDATE_INTERVAL_=_200,
> > MAX_NUMBER_OF_ANNEALING_STEPS_=_0, KILL_TIME_=_55]
> > Host: teraport
> > Directory: oops-20090331-1701-fpuie7be/jobs/d/runoops-dsmccq8j
> > stderr.txt:
> > stdout.txt:
> > Caused by:
> > org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> > java.lang.IllegalArgumentException: No worker with id=1956306968
> > at
> > org.globus.cog.abstraction.coaster.service.job.manager.CoasterTaskHandler.submit(CoasterTaskHandler.java:85)
> > at
> > org.globus.cog.abstraction.coaster.service.job.manager.CoasterQueueProcessor.run(CoasterQueueProcessor.java:71)
> > Caused by: java.lang.IllegalArgumentException: No worker with
> > id=1956306968
> > at
> > org.globus.cog.abstraction.coaster.service.job.manager.WorkerManager.getChannelContext(WorkerManager.java:483)
> > at
> > org.globus.cog.abstraction.coaster.service.job.manager.CoasterTaskHandler.submit(CoasterTaskHandler.java:78)
> > ... 1 more
> > Cleaning up...
> > Shutting down service at https://128.135.125.118:55513
> > Got channel MetaChannel: 22129174 -> GSSSChannel-null(1)
> > - Done
> > Command exited with non-zero status 2
> > real 1628.27
> > user 169.87
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
