[Swift-user] Running swift from firewalled host
Michael Wilde wilde at mcs.anl.gov
Sun Nov 16 12:29:38 CST 2008
On 11/16/08 11:39 AM, Mihael Hategan wrote:
> On Sun, 2008-11-16 at 11:25 -0600, Michael Wilde wrote:
>> Will swift running on a host with limited inbound port connectivity be
>> able to run jobs on a WS-GRAM site?
>> Based on the Globus firewall wiki page
> Link?
http://dev.globus.org/wiki/FirewallHowTo
>>  seems it should work (see below),
>> but thought I would ask before trying it.
>> - Mike
>> WS-GRAM:
>> Connections back to client (controllable ephemeral port to controllable
>> ephemeral port) required if executable or data staged from client or
>> output from job sent back to client.
>> ^^^ I assume Swift does not do either of these?
> Yes, however what that text fails to mention is that only polling for
> job status will work (not notifications). Swift does not use polling, so
> you need a an open port for the notification server.
Alas. So no way to run Swift-to-Globus from a host that you cant open up
  "controllable" ephemeral ports (like GLOBUS_TCP_PORT_RANGE) on, it seems?
- Mike
>> Port 8443/tcp is default and configurable.
>> GirdFTP:
>> In the case of a single data channel, the connection is established from
>> a controllable ephemeral port on the client to a controllable ephemeral
>> port on the server.
>> ^^^ Is this is what Swift does?
> Yes. So that's one additional port for each concurrent transfer.
> Basically you need a reasonable port range.
More information about the Swift-user mailing list
