[Swift-user] 1) disable retry mechanism and 2) continue on failure?
Mihael Hategan
hategan at mcs.anl.gov
Mon Mar 31 03:52:40 CDT 2008
On Sun, 2008-03-30 at 19:23 -0500, Quan Tran Pham wrote:
> Hi,
> > 1) How do we disable the retry mechanism, to make sure that Swift won't
> > retry failed jobs?
> I think you want to modify "execution.retries" in swift.properties.
> However, please remember that once a job fails (cannot retry anymore),
> he whole workflow stops.
Not necessarily. You can enable lazy errors.
> I think you need to change the Swift code to acquire "continue on
> failure". Or you might want to "cheat" Swift by adding some trigger
> jobs in front of your workflow? Then Swift will send many jobs at once
> after those trigger I believe.
> Regards
> Quan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
