[Swift-user] 1) disable retry mechanism and 2) continue on failure?
Quan Tran Pham
quanpt at cs.uchicago.edu
Sun Mar 30 19:23:34 CDT 2008
> 1) How do we disable the retry mechanism, to make sure that Swift won't
> retry failed jobs?
I think you want to modify "execution.retries" in swift.properties.
However, please remember that once a job fails (cannot retry anymore),
he whole workflow stops.
I think you need to change the Swift code to acquire "continue on
failure". Or you might want to "cheat" Swift by adding some trigger
jobs in front of your workflow? Then Swift will send many jobs at once
after those trigger I believe.
Regards
Quan
More information about the Swift-user
