[Swift-user] Re: [falkon-user] 1) disable retry mechanism and 2) continue on failure?
Zhao Zhang zhaozhang at uchicago.edu
Mon Mar 31 00:46:39 CDT 2008
Hi, Ben
Ben Clifford wrote:
>> After I changed the definition of runam() function in the swift script, it
>> seem everything is working now.
> I'm not sure that the below actually is working correctly from a swift
> perspective - it doesn't match up with my understanding of what the
> problem is/was.
It is ok for now.
>> Another Issue: Do you know where to set the path that swift is trying to copy
>> wrapper.sh from ?
> It copies it from libexec/ in your swift install directory. What are you
> trying to do?
Because we are running swift and falkon on BGP, and the read/write from
GPFS is not that fast, so we need to do a data caching. Precopy the
wrapper.sh to Compute Nodes's shared memory. So I was asking where does
swift copy wrapper.sh from.
thanks
zhao
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20080331/a0ba0eed/attachment.html>
More information about the Swift-user mailing list
