[Swift-user] debug log not being produced
Michael Wilde
wilde at mcs.anl.gov
Sat Mar 29 09:25:10 CDT 2008
I rebuild a clean swift from r1773 from scratch, without deef, on both
terminable and the bgp, then tested with a simple "swift first.swift" in
examples/vdsk.
On terminable I get the log file fine, on the bgp I dont.
On 3/29/08 8:27 AM, Mihael Hategan wrote:
> log4j.properties looks fine.
> What's in amps2-20080328-1720-6jit1g59.d and what does swift.out say?
The *.d dir was empty. That swift.out said:
Swift script amps2.swift starting at Fri Mar 28 17:20:12 CDT 2008
running on sites: bgps
Swift svn swift-r1771 cog-r1953
RunID: 20080328-1720-6jit1g59
Progress:
runam6 started
error: Notification(int timeout): socket = new ServerSocket(recvPort);
Address already in use
2008-03-28 17:20:27,788 WARN submitQueue.NonBlockingSubmit
[pool-1-thread-1,notifyPreviousQueue:71] Warning: Task handler throws
exception and also sets status
runam6 failed
Final status: Failed:1
The following errors have occurred:
1. Application "runam6" failed (Task failed)
Arguments: "000000, 0.200000, 0.000391, 0.204419, 0.200000,
0.000391, 0.204419, 10"
Host: bgps
Directory: amps2-20080328-1720-6jit1g59/jobs/a/runam6-a9750gqi
STDERR:
STDOUT:
Swift Script amps2.swift ended at Fri Mar 28 17:20:28 CDT 2008 with exit
code 0
it was that error that I was going after, and couldn't get the log file.
For the test I did on a fresh clean build of 1773 on the bgp, swift
stdout/err gave:
bg$ $s/bin/swift first.swift
RunID: 20080329-0913-xdviok1a
Progress:
echo started
echo completed
Final status: Finished successfully:1
bg$ ls
anonymous.swift default.dtm first.xml
helloworld_named.dtm regexp.swift
array_index.dtm diamond.dtm fixedarray.swift manyparam.swift
tutorial
array_iteration.dtm file_counter.dtm foreach.swift parameter.swift
types.swift
array_wildcard.dtm first.kml hello.txt q16.txt
arraymapper.dtm first.swift helloworld.dtm range.dtm
bg$ pwd
/home/wilde/swift/rev/1773c/examples/vdsk
bg$
Im using this java:
bg$ echo $JAVA_HOME
/home/falkon/java
bg$ which java
/home/falkon/java/bin/java
bg$ java -version
java version "1.5.0"
Java(TM) 2 Runtime Environment, Standard Edition (build
pxp64dev-20070511(SR5))
IBM J9 VM (build 2.3, J2RE 1.5.0 IBM J9 2.3 Linux ppc64-64
j9vmxp6423-20070426 (JIT enabled)
J9VM - 20070420_12448_BHdSMr
JIT - 20070419_1806_r8
GC - 200704_19)
JCL - 20070511
bg$
bg$ ls -l $JAVA_HOME
lrwxrwxrwx 1 wilde falkon 32 Mar 26 15:18 /home/falkon/java ->
/home/falkon/ibm-java2-ppc64-50/
- Mike
> Mihael
> On Sat, 2008-03-29 at 07:22 -0500, Michael Wilde wrote:
>> Im not getting a swift <runid>.log file on the BGP after rebuilding
>> swift to 1771 with provider-deef.
>> Im backtracking and debugging now, but does anyone know of recent
>> changes in this area, or of what I might have done wrong?
>> (I lost access to many files when my sicortex NFS client host crashed
>> and then went into limited access mode, so I may have mis-configured things)
>> Does anyone see a cause?
>> Thanks,
>> Mike
>> -- Im running swift with this script:
>> WORKFLOW=$1
>> shift
>> site $* >sites.xml
>> ( echo Swift script $WORKFLOW.swift starting at `date`
>> echo running on sites: $*
>> echo
>> swift \
>> -sites.file ./sites.xml \
>> -tc.file ./tc.data \
>> $WORKFLOW.swift
>> echo
>> echo Swift Script $WORKFLOW.swift ended at `date` with exit code $?
>> ) >swift.out 2>&1
>> -- etc/log4j.properties
>> bg$ cat log4j.properties
>> # Set root category priority to WARN and its appenders to CONSOLE and FILE.
>> log4j.rootCategory=INFO, CONSOLE, FILE
>> log4j.appender.CONSOLE=org.apache.log4j.ConsoleAppender
>> log4j.appender.CONSOLE.layout=org.apache.log4j.PatternLayout
>> log4j.appender.CONSOLE.Threshold=INFO
>> log4j.appender.CONSOLE.layout.ConversionPattern=%m%n
>> log4j.appender.FILE=org.apache.log4j.FileAppender
>> log4j.appender.FILE.File=swift.log
>> log4j.appender.FILE.layout=org.apache.log4j.PatternLayout
>> log4j.appender.FILE.layout.ConversionPattern=%d{yyyy-MM-dd
>> HH:mm:ss,SSSZZZZZ} %-5p %c{1} %m%n
>> log4j.logger.swift=DEBUG
>> log4j.logger.org.globus.swift.trace=INFO
>> log4j.logger.org.griphyn.vdl.karajan.Loader=DEBUG
>> log4j.logger.org.globus.cog.karajan.workflow.events.WorkerSweeper=WARN
>> log4j.logger.org.globus.cog.karajan.workflow.nodes.FlowNode=WARN
>> log4j.logger.org.globus.cog.karajan.scheduler.WeightedHostScoreScheduler=DEBUG
>> log4j.logger.org.griphyn.vdl.toolkit.VDLt2VDLx=DEBUG
>> log4j.logger.org.griphyn.vdl.karajan.VDL2ExecutionContext=DEBUG
>> log4j.logger.org.globus.cog.abstraction.impl.common.task.TaskImpl=DEBUG
>> log4j.logger.org.griphyn.vdl.karajan.lib.GetFieldValue=DEBUG
>> log4j.logger.org.griphyn.vdl.engine.Karajan=INFO
>> -- ~/.swift/swift.properties
>> sitedir.keep=true
>> wrapperlog.always.transfer=true
>> lazy.errors=true
>> execution.retries=0
>> #kickstart.always.transfer=true
>> throttle.submit=off
>> throttle.host.submit=off
>> throttle.transfers=20
>> throttle.file.operations=20
>> throttle.score.job.factor=1000000
>> -- run dir after a swift run - no .log file!
>> bg$ cd ~/mars/run01
>> bg$ ls -lt
>> total 1280
>> -rw-r--r-- 1 wilde users 908 Mar 28 17:20 swift.out
>> -rw-r--r-- 1 wilde users 48 Mar 28 17:20
>> amps2-20080328-1720-6jit1g59.0.rlog
>> drwxr-xr-x 2 wilde users 131072 Mar 28 17:20 amps2-20080328-1720-6jit1g59.d
>> -rw-r--r-- 1 wilde users 7859 Mar 28 17:20 amps2.kml
>> -rw-r--r-- 1 wilde users 4397 Mar 28 17:20 amps2.xml
>> -rw-r--r-- 1 wilde users 422 Mar 28 17:20 sites.xml
>> -rw-r--r-- 1 wilde users 103 Mar 28 16:02 paramlist
>> -rw-r--r-- 1 wilde users 1432 Mar 28 14:48 tc.data
>> -rw-r--r-- 1 wilde users 654 Mar 28 14:36 amps2.swift
>> bg$
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
