[Swift-user] debug log not being produced
Mihael Hategan
hategan at mcs.anl.gov
Sat Mar 29 08:27:57 CDT 2008
log4j.properties looks fine.
What's in amps2-20080328-1720-6jit1g59.d and what does swift.out say?
Mihael
On Sat, 2008-03-29 at 07:22 -0500, Michael Wilde wrote:
> Im not getting a swift <runid>.log file on the BGP after rebuilding
> swift to 1771 with provider-deef.
> Im backtracking and debugging now, but does anyone know of recent
> changes in this area, or of what I might have done wrong?
> (I lost access to many files when my sicortex NFS client host crashed
> and then went into limited access mode, so I may have mis-configured things)
> Does anyone see a cause?
> Thanks,
> Mike
> -- Im running swift with this script:
> WORKFLOW=$1
> shift
> site $* >sites.xml
> ( echo Swift script $WORKFLOW.swift starting at `date`
> echo running on sites: $*
> echo
> swift \
> -sites.file ./sites.xml \
> -tc.file ./tc.data \
> $WORKFLOW.swift
> echo
> echo Swift Script $WORKFLOW.swift ended at `date` with exit code $?
> ) >swift.out 2>&1
> -- etc/log4j.properties
> bg$ cat log4j.properties
> # Set root category priority to WARN and its appenders to CONSOLE and FILE.
> log4j.rootCategory=INFO, CONSOLE, FILE
> log4j.appender.CONSOLE=org.apache.log4j.ConsoleAppender
> log4j.appender.CONSOLE.layout=org.apache.log4j.PatternLayout
> log4j.appender.CONSOLE.Threshold=INFO
> log4j.appender.CONSOLE.layout.ConversionPattern=%m%n
> log4j.appender.FILE=org.apache.log4j.FileAppender
> log4j.appender.FILE.File=swift.log
> log4j.appender.FILE.layout=org.apache.log4j.PatternLayout
> log4j.appender.FILE.layout.ConversionPattern=%d{yyyy-MM-dd
> HH:mm:ss,SSSZZZZZ} %-5p %c{1} %m%n
> log4j.logger.swift=DEBUG
> log4j.logger.org.globus.swift.trace=INFO
> log4j.logger.org.griphyn.vdl.karajan.Loader=DEBUG
> log4j.logger.org.globus.cog.karajan.workflow.events.WorkerSweeper=WARN
> log4j.logger.org.globus.cog.karajan.workflow.nodes.FlowNode=WARN
> log4j.logger.org.globus.cog.karajan.scheduler.WeightedHostScoreScheduler=DEBUG
> log4j.logger.org.griphyn.vdl.toolkit.VDLt2VDLx=DEBUG
> log4j.logger.org.griphyn.vdl.karajan.VDL2ExecutionContext=DEBUG
> log4j.logger.org.globus.cog.abstraction.impl.common.task.TaskImpl=DEBUG
> log4j.logger.org.griphyn.vdl.karajan.lib.GetFieldValue=DEBUG
> log4j.logger.org.griphyn.vdl.engine.Karajan=INFO
> -- ~/.swift/swift.properties
> sitedir.keep=true
> wrapperlog.always.transfer=true
> lazy.errors=true
> execution.retries=0
> #kickstart.always.transfer=true
> throttle.submit=off
> throttle.host.submit=off
> throttle.transfers=20
> throttle.file.operations=20
> throttle.score.job.factor=1000000
> -- run dir after a swift run - no .log file!
> bg$ cd ~/mars/run01
> bg$ ls -lt
> total 1280
> -rw-r--r-- 1 wilde users 908 Mar 28 17:20 swift.out
> -rw-r--r-- 1 wilde users 48 Mar 28 17:20
> amps2-20080328-1720-6jit1g59.0.rlog
> drwxr-xr-x 2 wilde users 131072 Mar 28 17:20 amps2-20080328-1720-6jit1g59.d
> -rw-r--r-- 1 wilde users 7859 Mar 28 17:20 amps2.kml
> -rw-r--r-- 1 wilde users 4397 Mar 28 17:20 amps2.xml
> -rw-r--r-- 1 wilde users 422 Mar 28 17:20 sites.xml
> -rw-r--r-- 1 wilde users 103 Mar 28 16:02 paramlist
> -rw-r--r-- 1 wilde users 1432 Mar 28 14:48 tc.data
> -rw-r--r-- 1 wilde users 654 Mar 28 14:36 amps2.swift
> bg$
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
