[Swift-user] debug log not being produced
Michael Wilde
wilde at mcs.anl.gov
Sat Mar 29 07:22:33 CDT 2008
Im not getting a swift <runid>.log file on the BGP after rebuilding
swift to 1771 with provider-deef.
Im backtracking and debugging now, but does anyone know of recent
changes in this area, or of what I might have done wrong?
(I lost access to many files when my sicortex NFS client host crashed
and then went into limited access mode, so I may have mis-configured things)
Does anyone see a cause?
Mike
-- Im running swift with this script:
WORKFLOW=$1
shift
site $* >sites.xml
( echo Swift script $WORKFLOW.swift starting at `date`
echo running on sites: $*
echo
swift \
-sites.file ./sites.xml \
-tc.file ./tc.data \
$WORKFLOW.swift
echo
echo Swift Script $WORKFLOW.swift ended at `date` with exit code $?
) >swift.out 2>&1
-- etc/log4j.properties
bg$ cat log4j.properties
# Set root category priority to WARN and its appenders to CONSOLE and FILE.
log4j.rootCategory=INFO, CONSOLE, FILE
log4j.appender.CONSOLE=org.apache.log4j.ConsoleAppender
log4j.appender.CONSOLE.layout=org.apache.log4j.PatternLayout
log4j.appender.CONSOLE.Threshold=INFO
log4j.appender.CONSOLE.layout.ConversionPattern=%m%n
log4j.appender.FILE=org.apache.log4j.FileAppender
log4j.appender.FILE.File=swift.log
log4j.appender.FILE.layout=org.apache.log4j.PatternLayout
log4j.appender.FILE.layout.ConversionPattern=%d{yyyy-MM-dd
HH:mm:ss,SSSZZZZZ} %-5p %c{1} %m%n
log4j.logger.swift=DEBUG
log4j.logger.org.globus.swift.trace=INFO
log4j.logger.org.griphyn.vdl.karajan.Loader=DEBUG
log4j.logger.org.globus.cog.karajan.workflow.events.WorkerSweeper=WARN
log4j.logger.org.globus.cog.karajan.workflow.nodes.FlowNode=WARN
log4j.logger.org.globus.cog.karajan.scheduler.WeightedHostScoreScheduler=DEBUG
log4j.logger.org.griphyn.vdl.toolkit.VDLt2VDLx=DEBUG
log4j.logger.org.griphyn.vdl.karajan.VDL2ExecutionContext=DEBUG
log4j.logger.org.globus.cog.abstraction.impl.common.task.TaskImpl=DEBUG
log4j.logger.org.griphyn.vdl.karajan.lib.GetFieldValue=DEBUG
log4j.logger.org.griphyn.vdl.engine.Karajan=INFO
-- ~/.swift/swift.properties
sitedir.keep=true
wrapperlog.always.transfer=true
lazy.errors=true
execution.retries=0
#kickstart.always.transfer=true
throttle.submit=off
throttle.host.submit=off
throttle.transfers=20
throttle.file.operations=20
throttle.score.job.factor=1000000
-- run dir after a swift run - no .log file!
bg$ cd ~/mars/run01
bg$ ls -lt
total 1280
-rw-r--r-- 1 wilde users 908 Mar 28 17:20 swift.out
-rw-r--r-- 1 wilde users 48 Mar 28 17:20
amps2-20080328-1720-6jit1g59.0.rlog
drwxr-xr-x 2 wilde users 131072 Mar 28 17:20 amps2-20080328-1720-6jit1g59.d
-rw-r--r-- 1 wilde users 7859 Mar 28 17:20 amps2.kml
-rw-r--r-- 1 wilde users 4397 Mar 28 17:20 amps2.xml
-rw-r--r-- 1 wilde users 422 Mar 28 17:20 sites.xml
-rw-r--r-- 1 wilde users 103 Mar 28 16:02 paramlist
-rw-r--r-- 1 wilde users 1432 Mar 28 14:48 tc.data
-rw-r--r-- 1 wilde users 654 Mar 28 14:36 amps2.swift
bg$
More information about the Swift-user
