[Swift-user] iterate doesn't stop
Ben Clifford
benc at hawaga.org.uk
Wed Mar 26 20:43:17 CDT 2008
On Wed, 26 Mar 2008, Luciano Piccoli wrote:
> However, if the number of iterations N is read from the command line it does
> not stop:
> -- iterate.swift -------
> int N=@arg("N");
> iterate i {
> print (i);
> } until (i == N);
> Any ideas why?
That shouldn't even compile because the types aren't correct.
@args returns a String, "5"; which is never the same as the number 5.
Not enough type checking going on there - it should fail here:
> int N=@arg("N");
However, it doesn't because the compiler doesn't type check enough.
I just committed (in r1772) a function, @toint, that you can use like
this:
int N=@toint(@arg("N"));
I've used it in the past for exactly this purpose.
More information about the Swift-user
