[Swift-user] Using swift with falkon on teraport
Quan Tran Pham quanpt at cs.uchicago.edu
Tue Mar 25 11:36:22 CDT 2008
Thank you Mike,
I have Falkon built already, now I should recompile swift.
I think the Swift with Falkon part should be put up on
"http://dev.globus.org/wiki/Incubator/Falkon#Project_Branches", at
"Running Swift Applications over Falkon" so that others can have some
reference.
Regards
Quan Pham
On Tue, Mar 25, 2008 at 11:18 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Hi Quan,
>  I'm doing something similar at the moment on machines at Argonne.
>  Do you already have Falkon built? (I'm using the attached file of notes
>  that I compiled from Ioan).
>  I run swift and falkon together on a host that has access to the cluster
>  shared filesystem, which in your case would be tp-login (or better yet a
>  cluster node that you can allocate using qsub -I, as as not to over-tax
>  a login host).
>  I use the local data provider, so that swift uses direct
>  shared-filesystem access to move data back and forth and do directory
>  and status file management.
>  Here's my sites file:
>  Below is my working doc of info form Ioan and Zhao, also attached in word.
>  - Mike
More information about the Swift-user mailing list
