[Swift-user] Fwd: Too many open files problem
Ben Clifford benc at hawaga.org.uk
Mon Mar 17 21:43:05 CDT 2008
Hi.  Can you describe your problem some more:
Doe it happen with every swift script (for example, with the example
first.swift)?
Does it happenw hen you run a large workflow?
If you make that run smaller (eg fewer input files) does the problem go
away? At what point?
Can you send the swiftscript source code that you are using?
> From: Quan Tran Pham <quanpt at cs.uchicago.edu>
> Date: Mon, Mar 17, 2008 at 10:43 AM
> Hi all,
> I did find a thread about this problem "Too many open files" in the
> swift-user previous mails, but I could not find any solution yet. Can
> someone please tell me what is the problem/solution?
>  I used:
> Swift v0.3-dev r1684
> on tp-login2.ci (ulimit said: open files = 1024)
> Thank you very much
More information about the Swift-user mailing list
