[Swift-user] Submitting first.swift to another node
Jeffrey Wells
jwells2 at twcny.rr.com
Sun Mar 2 16:22:54 CST 2008
All;
I am new to Swift and I am trying to implement a simple test on our grid. Any help or direction would be appreciated.
Jeff Wells
Once I inoke the swift command workflow starts but hangs on the line below:
Recompilation suppressed.
Using sites file: /home/wells/Desktop/sites.xml
Using tc.data: /usr/local/swift/etc/tc.data
Swift v0.3 r1319 (modified locally)
RunID: 20080302-1719-dyd3zjg5
echo started
START thread=0 tr=echo
START host=ruth - Initializing shared directory
Task(type=FILE_OPERATION, identity=urn:0-1204496396858) setting status to Active
Task(type=FILE_OPERATION, identity=urn:0-1204496396858) setting status to Completed
Task(type=FILE_TRANSFER, identity=urn:0-1204496396861) setting status to Submitted
Task(type=FILE_TRANSFER, identity=urn:0-1204496396861) setting status to Active
Task(type=FILE_TRANSFER, identity=urn:0-1204496396861) setting status to Completed
Task(type=FILE_TRANSFER, identity=urn:0-1204496396865) setting status to Submitted
Task(type=FILE_TRANSFER, identity=urn:0-1204496396865) setting status to Active
Task(type=FILE_TRANSFER, identity=urn:0-1204496396865) setting status to Completed
Task(type=FILE_OPERATION, identity=urn:0-1204496396868) setting status to Active
Task(type=FILE_OPERATION, identity=urn:0-1204496396868) setting status to Completed
Task(type=FILE_OPERATION, identity=urn:0-1204496396870) setting status to Active
Task(type=FILE_OPERATION, identity=urn:0-1204496396870) setting status to Completed
Task(type=FILE_OPERATION, identity=urn:0-1204496396872) setting status to Active
Task(type=FILE_OPERATION, identity=urn:0-1204496396872) setting status to Completed
END host=ruth - Done initializing shared directory
THREAD_ASSOCIATION jobid=echo-01e588pi thread=0 host=ruth
START jobid=echo-01e588pi host=ruth - Initializing directory structure
Creating directory structure in first-20080302-1719-dyd3zjg5/shared (first-20080302-1719-dyd3zjg5/shared/)
Task(type=FILE_OPERATION, identity=urn:0-1204496396874) setting status to Active
Task(type=FILE_OPERATION, identity=urn:0-1204496396874) setting status to Completed
END jobid=echo-01e588pi - Done initializing directory structure
START jobid=echo-01e588pi - Staging in files
END jobid=echo-01e588pi - Staging in finished
JOB_START jobid=echo-01e588pi tr=echo arguments=[Hello, world!] tmpdir=first-20080302-1719-dyd3zjg5/echo-01e588pi host=ruth
****<hangs>*****
The sites.xml was modified so that the first.swift script would be run our remote machine.
<pool handle="ruth" sysinfo="INTEL32::LINUX">
<gridftp url="gsiftp://ruth.cs.sunyit.edu" storage="/tmp" major="2" minor="2" patch="4" />
<jobmanager universe="vanilla" url="ruth.cs.sunyit.edu:8443/wsrf/services/ManagedJobFactoryService" major="2" minor="2" patch="4" />
<workdirectory >/tmp</workdirectory>
</pool>
My command line is:
swift -sites.file sites.xml first.swift -verbose -debug
The exception is:
2008-03-02 16:27:29,523-0500 DEBUG Loader Recompilation suppressed.
2008-03-02 16:27:31,929-0500 INFO unknown Using sites file: /home/wells/Desktop/sites.xml
2008-03-02 16:27:31,936-0500 INFO unknown Using tc.data: /usr/local/swift/etc/tc.data
2008-03-02 16:27:33,338-0500 INFO unknown Swift v0.3 r1319 (modified locally)
2008-03-02 16:27:33,341-0500 INFO unknown RunID: 20080302-1627-dzk4seng
2008-03-02 16:27:33,574-0500 INFO vdl:execute START thread=0 tr=echo
2008-03-02 16:27:33,604-0500 INFO vdl:initshareddir START host=ruth - Initializing shared directory
2008-03-02 16:27:35,633-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250899) setting status to Active
2008-03-02 16:27:35,660-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250899) setting status to Completed
2008-03-02 16:27:35,700-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250902) setting status to Submitted
2008-03-02 16:27:35,702-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250902) setting status to Active
2008-03-02 16:27:36,269-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250902) setting status to Completed
2008-03-02 16:27:36,272-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250906) setting status to Submitted
2008-03-02 16:27:36,273-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250906) setting status to Active
2008-03-02 16:27:36,486-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250906) setting status to Completed
2008-03-02 16:27:36,488-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250909) setting status to Active
2008-03-02 16:27:36,496-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250909) setting status to Completed
2008-03-02 16:27:36,498-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250911) setting status to Active
2008-03-02 16:27:36,513-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250911) setting status to Completed
2008-03-02 16:27:36,516-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250913) setting status to Active
2008-03-02 16:27:36,521-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250913) setting status to Completed
2008-03-02 16:27:36,524-0500 INFO vdl:initshareddir END host=ruth - Done initializing shared directory
2008-03-02 16:27:36,527-0500 DEBUG vdl:execute2 THREAD_ASSOCIATION jobid=echo-kv0268pi thread=0 host=ruth
2008-03-02 16:27:36,539-0500 INFO vdl:createdirset START jobid=echo-kv0268pi host=ruth - Initializing directory structure
2008-03-02 16:27:36,544-0500 INFO vdl:createdirs Creating directory structure in first-20080302-1627-dzk4seng/shared (first-20080302-1627-dzk4seng/shared/)
2008-03-02 16:27:36,545-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250915) setting status to Active
2008-03-02 16:27:36,549-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250915) setting status to Completed
2008-03-02 16:27:36,551-0500 INFO vdl:createdirset END jobid=echo-kv0268pi - Done initializing directory structure
2008-03-02 16:27:36,552-0500 INFO vdl:dostagein START jobid=echo-kv0268pi - Staging in files
2008-03-02 16:27:36,554-0500 INFO vdl:dostagein END jobid=echo-kv0268pi - Staging in finished
2008-03-02 16:27:36,556-0500 DEBUG vdl:execute2 JOB_START jobid=echo-kv0268pi tr=echo arguments=[Hello, world!] tmpdir=first-20080302-1627-dzk4seng/echo-kv0268pi host=ruth
2008-03-02 16:30:36,747-0500 DEBUG TaskImpl Task(type=JOB_SUBMISSION, identity=urn:0-1204493250917) setting status to Failed null
2008-03-02 16:30:36,761-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION jobid=echo-kv0268pi - Application exception: null
task:execute @ vdl-int.k, line: 360
sys:sequential @ vdl-int.k, line: 353
sys:try @ vdl-int.k, line: 352
task:allocatehost @ vdl-int.k, line: 334
vdl:execute2 @ execute-default.k, line: 23
sys:restartonerror @ execute-default.k, line: 21
sys:sequential @ execute-default.k, line: 19
sys:try @ execute-default.k, line: 18
sys:if @ execute-default.k, line: 17
sys:then @ execute-default.k, line: 16
sys:if @ execute-default.k, line: 15
vdl:execute @ first.kml, line: 16
greeting @ first.kml, line: 43
vdl:mainp @ first.kml, line: 42
mainp @ vdl.k, line: 144
vdl:mains @ first.kml, line: 41
rlog:restartlog @ first.kml, line: 39
kernel:project @ first.kml, line: 2
Caused by: java.lang.ClassCastException
at org.globus.gsi.bc.BouncyCastleCertProcessingFactory.createCertificate(BouncyCastleCertProcessingFactory.java:165)
at org.globus.gsi.bc.BouncyCastleCertProcessingFactory.createCertificate(BouncyCastleCertProcessingFactory.java:92)
at org.globus.gsi.gssapi.GlobusGSSContextImpl.initSecContext(GlobusGSSContextImpl.java:571)
at org.globus.gsi.gssapi.net.GssSocket.authenticateClient(GssSocket.java:107)
at org.globus.gsi.gssapi.net.GssSocket.startHandshake(GssSocket.java:145)
at org.globus.gsi.gssapi.net.GssSocket.getOutputStream(GssSocket.java:166)
at org.globus.gram.Gram.request(Gram.java:315)
at org.globus.gram.GramJob.request(GramJob.java:262)
at org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submitSingleJob(JobSubmissionTaskHandler.java:136)
at org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.submit(JobSubmissionTaskHandler.java:92)
at org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:54)
at org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:83)
at edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:431)
at edu.emory.mathcs.backport.java.util.concurrent.FutureTask.run(FutureTask.java:166)
at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:643)
at edu.emory.mathcs.backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:668)
at java.lang.Thread.run(Thread.java:534)
2008-03-02 16:30:36,781-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250919) setting status to Submitted
2008-03-02 16:30:36,782-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250919) setting status to Active
2008-03-02 16:30:37,271-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250919) setting status to Failed Exception in getFile
2008-03-02 16:30:37,275-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250923) setting status to Active
2008-03-02 16:30:37,276-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250923) setting status to Completed
2008-03-02 16:30:37,281-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250927) setting status to Submitted
2008-03-02 16:30:37,282-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250927) setting status to Active
2008-03-02 16:30:37,506-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250927) setting status to Failed Exception in getFile
2008-03-02 16:30:37,508-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250930) setting status to Active
2008-03-02 16:30:37,509-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250930) setting status to Completed
2008-03-02 16:30:37,521-0500 DEBUG vdl:execute2 THREAD_ASSOCIATION jobid=echo-lv0268pi thread=0 host=ruth
2008-03-02 16:30:37,525-0500 INFO vdl:createdirset START jobid=echo-lv0268pi host=ruth - Initializing directory structure
2008-03-02 16:30:37,526-0500 INFO vdl:createdirset END jobid=echo-lv0268pi - Done initializing directory structure
2008-03-02 16:30:37,528-0500 INFO vdl:dostagein START jobid=echo-lv0268pi - Staging in files
2008-03-02 16:30:37,528-0500 INFO vdl:dostagein END jobid=echo-lv0268pi - Staging in finished
2008-03-02 16:30:37,529-0500 DEBUG vdl:execute2 JOB_START jobid=echo-lv0268pi tr=echo arguments=[Hello, world!] tmpdir=first-20080302-1627-dzk4seng/echo-lv0268pi host=ruth
2008-03-02 16:33:37,633-0500 DEBUG TaskImpl Task(type=JOB_SUBMISSION, identity=urn:0-1204493250934) setting status to Failed null
2008-03-02 16:33:37,635-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION jobid=echo-lv0268pi - Application exception: null
2008-03-02 16:33:37,640-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250936) setting status to Submitted
2008-03-02 16:33:37,641-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250936) setting status to Active
2008-03-02 16:33:38,060-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250936) setting status to Failed Exception in getFile
2008-03-02 16:33:38,064-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250940) setting status to Active
2008-03-02 16:33:38,065-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250940) setting status to Completed
2008-03-02 16:33:38,068-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250944) setting status to Submitted
2008-03-02 16:33:38,069-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250944) setting status to Active
2008-03-02 16:33:38,098-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250944) setting status to Failed Exception in getFile
2008-03-02 16:33:38,101-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250947) setting status to Active
2008-03-02 16:33:38,102-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250947) setting status to Completed
2008-03-02 16:33:38,113-0500 DEBUG vdl:execute2 THREAD_ASSOCIATION jobid=echo-mv0268pi thread=0 host=ruth
2008-03-02 16:33:38,117-0500 INFO vdl:createdirset START jobid=echo-mv0268pi host=ruth - Initializing directory structure
2008-03-02 16:33:38,119-0500 INFO vdl:createdirset END jobid=echo-mv0268pi - Done initializing directory structure
2008-03-02 16:33:38,120-0500 INFO vdl:dostagein START jobid=echo-mv0268pi - Staging in files
2008-03-02 16:33:38,120-0500 INFO vdl:dostagein END jobid=echo-mv0268pi - Staging in finished
2008-03-02 16:33:38,121-0500 DEBUG vdl:execute2 JOB_START jobid=echo-mv0268pi tr=echo arguments=[Hello, world!] tmpdir=first-20080302-1627-dzk4seng/echo-mv0268pi host=ruth
2008-03-02 16:36:38,203-0500 DEBUG TaskImpl Task(type=JOB_SUBMISSION, identity=urn:0-1204493250951) setting status to Failed null
2008-03-02 16:36:38,205-0500 DEBUG vdl:execute2 APPLICATION_EXCEPTION jobid=echo-mv0268pi - Application exception: null
2008-03-02 16:36:38,213-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250953) setting status to Submitted
2008-03-02 16:36:38,214-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250953) setting status to Active
2008-03-02 16:36:38,703-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250953) setting status to Failed Exception in getFile
2008-03-02 16:36:38,706-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250957) setting status to Active
2008-03-02 16:36:38,707-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250957) setting status to Completed
2008-03-02 16:36:38,710-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250961) setting status to Submitted
2008-03-02 16:36:38,711-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250961) setting status to Active
2008-03-02 16:36:38,923-0500 DEBUG TaskImpl Task(type=FILE_TRANSFER, identity=urn:0-1204493250961) setting status to Failed Exception in getFile
2008-03-02 16:36:38,926-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250964) setting status to Active
2008-03-02 16:36:38,928-0500 DEBUG TaskImpl Task(type=FILE_OPERATION, identity=urn:0-1204493250964) setting status to Completed
2008-03-02 16:36:38,934-0500 INFO vdl:execute END_FAILURE thread=0 tr=echo
2008-03-02 16:36:38,942-0500 DEBUG VDL2ExecutionContext Exception in echo:
Arguments: [Hello, world!]
Host: ruth
Directory: first-20080302-1627-dzk4seng/echo-mv0268pi
stderr.txt:
stdout.txt:
Exception in echo:
Host: ruth
stderr.txt:
stdout.txt:
sys:exception @ vdl-int.k, line: 416
sys:throw @ vdl-int.k, line: 415
sys:catch @ vdl-int.k, line: 393
Caused by: null
at org.globus.cog.karajan.workflow.nodes.functions.KException.function(KException.java:29)
at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:45)
at org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java:192)
at org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:33)
at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:335)
at org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java:123)
at org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java:97)
at org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java:173)
at org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:299)
at org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:46)
at org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:51)
at org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:27)
at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.executeChildren(AbstractFunction.java:40)
at org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
at org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:240)
at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:281)
at org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java:393)
at org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java:332)
at org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java:227)
at org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
Caused by: null
at org.globus.cog.karajan.workflow.events.FailureNotificationEvent.<init>(FailureNotificationEvent.java:36)
at org.globus.cog.karajan.workflow.events.FailureNotificationEvent.<init>(FailureNotificationEvent.java:42)
at org.globus.cog.karajan.workflow.nodes.FlowNode.failImmediately(FlowNode.java:152)
at org.globus.cog.karajan.workflow.nodes.grid.GridExec.taskFailed(GridExec.java:300)
at org.globus.cog.karajan.workflow.nodes.grid.AbstractGridNode.statusChanged(AbstractGridNode.java:271)
at org.globus.cog.karajan.scheduler.AbstractScheduler.fireJobStatusChangeEvent(AbstractScheduler.java:165)
at org.globus.cog.karajan.scheduler.LateBindingScheduler.statusChanged(LateBindingScheduler.java:647)
at org.globus.cog.karajan.scheduler.WeightedHostScoreScheduler.statusChanged(WeightedHostScoreScheduler.java:367)
at org.griphyn.vdl.karajan.VDSAdaptiveScheduler.statusChanged(VDSAdaptiveScheduler.java:403)
at org.globus.cog.abstraction.impl.common.task.TaskImpl.setStatus(TaskImpl.java:216)
at org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.notifyPreviousQueue(NonBlockingSubmit.java:74)
at org.globus.cog.karajan.scheduler.submitQueue.AbstractSubmitQueue.submitCompleted(AbstractSubmitQueue.java:35)
at org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.notifyPreviousQueue(NonBlockingSubmit.java:58)
at org.globus.cog.karajan.scheduler.submitQueue.NullQueue.submitCompleted(NullQueue.java:18)
at org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:87)
... 5 more
2008-03-02 16:36:39,103-0500 DEBUG Loader Swift finished - workflow had errors
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20080302/e03f8db0/attachment.html>
More information about the Swift-user
