[Swift-user] Running first.swift remotely on NCSA
Ben Clifford benc at hawaga.org.uk
Sun Jun 22 14:05:58 CDT 2008
On Fri, 20 Jun 2008, Andriy Fedorov wrote:
> The problem turned out to be in the setup of our firewall. For the
> time being, I cannot resolve it, so I am trying to use TeraGrid UC
> site for testing.
Were you running the Swift command on a TG UC login node, submitting to TG
UC?
> $ swift first.swift
> Unable to find required classes (javax.activation.DataHandler and
> javax.mail.internet.MimeMultipart). Attachment support is disabled.
> Swift 0.5 swift-r1783 cog-r1962
> RunID: 20080620-1514-in8cf2yg
> Progress:
> echo_gt2_pbs started
> Progress:  Stage in:1
> Progress:  Executing:1
The above looks more like something I'd expect from a WS-GRAM setup -
specifically, the "Unable to find required classes..." message (which is
safe to ignore here) and the symptom of going into "Executing" state,
seeing it run in qstat but not detected so by Swift.
Please can you run this one again and check that you really are submitting
to pre-WS gram there?
More information about the Swift-user mailing list
