[Swift-user] Running first.swift remotely on NCSA
Andriy Fedorov
fedorov at cs.wm.edu
Fri Jun 13 09:34:05 CDT 2008
> You'll need to do some more troubleshooting.
> Id try the following:
> - Start swift as you did before and wait for the job to be submitted
> - figure out what port the callback service is on (do a netstat -lntp)
> - log into NCSA and see if you can telnet to GLOBUS_HOSTNAME:port. You
> probably can't. You'll have to figure out why.
Yep, you were right...
[fedorov at ri ~/.globus] netstat -lntp | grep java
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
tcp 0 0 0.0.0.0:45000 0.0.0.0:*
LISTEN 25468/java
tcp 0 0 127.0.0.1:10479 0.0.0.0:*
LISTEN 25468/java
and telnet to port 45000 from Mercury gets "connection refused"
To add more details, I am unable to execute jobs via globusrun either:
[fedorov at ri vdsk] globusrun -o -r grid-hg.ncsa.teragrid.org/jobmanager
'&(executable=/usr/bin/cal)'
GRAM Job submission failed
org.globus.gram.GramException: The job manager failed to open stderr
at org.globus.gram.Gram.request(Gram.java:358)
at org.globus.gram.GramJob.request(GramJob.java:262)
at org.globus.tools.GlobusRun.gramRun(GlobusRun.java:557)
at org.globus.tools.GlobusRun.main(GlobusRun.java:530)
GRAM Job submission failed: The job manager failed to open stderr
I will have to figure it out...
Andrey
More information about the Swift-user
