[Swift-user] Running first.swift remotely on NCSA
Mihael Hategan hategan at mcs.anl.gov
Fri Jun 13 08:59:41 CDT 2008
> I got "grid-hg.ncsa.teragrid.org/jobmanager" from here:
> http://www.teragrid.org/userinfo/jobs/gram.php I think it is just an
> alias for "fork".
That makes sense/
> I also tried to use "jobmanager-pbs", and I could see my job in the
> queue, but the same result "Progress:  Executing:1" on the client
> host.
Ok, that's good.
> >> [fedorov at ri vdsk] swift first.swift
> >> Swift 0.5 swift-r1783 cog-r1962
> >> RunID: 20080612-2101-yvp36l3c
> >> Progress:
> >> echo started
> > This may happen if the callback address for you submit host is unknown
> > to the GRAM service or if you're behind a fierewall or NAT. If you're
> > not, try setting $GLOBUS_HOSTNAME with your DNS address or IP.
> No, I have a valid IP. I do have $GLOBUS_HOSTNAME set now, but this
> doesn't help.
Well, your problem is somewhere around there.
> It seems that there is a problem returning the result back. I tried to
> set GLOBUS_TCP_PORT_RANGE to 45000,45100, as suggested here
I don't think setting them to a random range will help. It would need to
match an open port range on your assumed firewall.
> http://www-128.ibm.com/developerworks/cn/grid/gr-gsi4intro/index_eng.html,
> but this also was of no help.
> Does anybody know what is wrong?
You'll need to do some more troubleshooting.
Id try the following:
- Start swift as you did before and wait for the job to be submitted
- figure out what port the callback service is on (do a netstat -lntp)
- log into NCSA and see if you can telnet to GLOBUS_HOSTNAME:port. You
probably can't. You'll have to figure out why.
Mihael
> Fedorov
More information about the Swift-user mailing list
