[Swift-user] Performance of Swift
Ioan Raicu
iraicu at cs.uchicago.edu
Tue Jun 3 11:05:57 CDT 2008
There are several papers out there from our group that shows different
aspects of performance of Swift. Here are a few:
* http://people.cs.uchicago.edu/~iraicu/publications/2008_NOVA08_book-chapter_Swift.pdf
o Figure 9: Shows the memory footprint per job (aka tasks, or
nodes in the DAG graph)
+ shows memory footprint of 3.2KB per node
o Figure 18: Shows a large scale application
+ 20K tasks on 200 CPUs with average task lengths of 200
seconds is a comfortable range for Swift and Falkon
+ we have more recent results, not published yet, that
has 16K tasks on 2048 CPUs with an average task length
of 87 seconds which worked well
* http://people.cs.uchicago.edu/~iraicu/publications/2007_SWF07_Swift.pdf
o Figure 6: Shows the speedup achieved with different task lengths
+ Conclusion is that using multi-level scheduling with
the Falkon provider, even tasks in the range of
seconds long can achieve good speedup
o Figure 7: Shows the throughput in tasks/sec achieved by Swift
+ shows Swift achieving 50+ tasks/sec throughputs using
Falkon
+ the paragraph right after this figure mentions that
Swift running directly with GRAM2 and PBS can achieve
2 jobs/sec; the implication of this is that jobs
typically take 15~60 seconds to startup, which
reflects the cost of scheduling, scheduling cycles,
and local resource manager's (LRM) time to setup the
remote nodes; there are also limitations on how many
jobs can be submitted at a time, as each job queued
might consume some resources on the LRM, or there
might be policies in place that limit the number of
jobs that can be queued; this means that aggressive
throttling must take place, which in practice, reduces
the sustained rate that Swift can submit/execute jobs
to a single site, to even lower than 2 jobs/sec
So, to answer you question, the performance of Swift (and any other
workflow system) will heavily rely on how efficient you can dispatch
jobs/tasks to remote resources, how long jobs/tasks are, how data
intensive the application is, and how much data movement must happen
before the job runs and after. If you have a fast enough file system,
and your application execution times are small, you can expect anywhere
from 1 to 50 jobs/sec from Swift, depending on what technologies you use
to interface between Swift and the remote resources (e.g. GRAM, PBS,
Condor, Falkon, etc).
Cheers,
Ioan
J A wrote:
> Hi All:
> Based on my reading, the performance from execution a swift workflow
> depends on the parallelism that a workflow has.
> If I have a workflow that contains several processors where each
> processor (procedure) depends on the previous one (output of a
> processor "A" is the input for processors "B" and so on.)
> How the performance of using swift in this case compare to other
> systems that execute workflows where there isn't any parallelism in
> the workflow?
> Thanks,
> Jamal
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web: http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20080603/73779a77/attachment.html>
More information about the Swift-user
