[Swift-user] Illegal character
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Jul 29 12:11:09 CDT 2008
And I see that you're using Swift 0.5, which may not have the CLASSPATH
improvements in the swift command as Ben mentioned.
Ben, should the nightly builds show up on this page, and if so should
local developers use those to get a recent snapshot:
   http://www.ci.uchicago.edu/swift/tests/tests-2008-07-13.html#packages
(in other words, is that page broken, or was it never intended to be a
source of nightly snapshots for download?)
You can also build your own Swift release from SVN. Instructions are at:
http://www.ci.uchicago.edu/swift/downloads/index.php
- Mike
On 7/29/08 11:21 AM, Ben Clifford wrote:
> (I removed CI support as this is not their business now)
> The fifth byte of the 19th line of your tc.data file is something
> unexpected.
> Type:
> hexdump -C tc.data
> (for the tc.data file that you are using)
> and send that output.
> On Tue, 29 Jul 2008, Zhengxiong Hou wrote:
>> Hi Mike,
>>    Yes,you are right.
>>    If I unset CLASSPATH in .soft.cache.sh, or just mark
>> #@osg in the .soft file, the original error disappeared.
>>    But there is a new ERROR, although swift job was finished.
>> [houzx at communicado dock]$ swift flipper.swift
>> 2008.07.29 11:05:59.115 CDT: [ERROR] Parsing profiles on
>> line 19 Illegal character '    'at position 5 :Illegal
>> character '     '
>> Swift 0.5 swift-r1783 cog-r1962
>> RunID: 20080729-1105-qbqofzya
>> Progress:
>> convert started
>> 2008.07.29 11:05:59.900 CDT: [ERROR] Parsing profiles on
>> character '     '
>> convert completed
>> Final status:  Finished successfully:1 Finished:1
More information about the Swift-user
