[Swift-user] Re: [Swift-devel] A naive run of Falkon+Swift on BGP login node.
Zhao Zhang
zhaozhang at uchicago.edu
Mon Jul 21 18:04:41 CDT 2008
In this test case, it actually worked. I talked with Mike, and we don't
quite understand these 2 things. So I sent them out.
After that I started another test. Running, swift on Login Node, falkon
service on IO node, and BGexec on CN.
At the very end of the service log, I got his:
847.985 2 2 25 256 256 0 0 0 0 0 0 0 0.0 2 0 0 0 0 0 0 0 0 0.0 0.0 0 0
100 512 288 512
848.985 2 2 25 256 256 0 0 0 0 0 0 0 0.0 2 0 0 0 0 0 0 0 0 0.0 0.0 0 0
100 512 288 512
849.985 2 2 25 256 256 0 0 0 0 0 0 0 0.0 2 0 0 0 0 0 0 0 0 0.0 0.0 0 0
100 512 287 512
850.985 2 2 25 256 256 0 0 0 0 0 0 0 0.0 2 0 0 0 0 0 0 0 0 0.0 0.0 0 0
100 512 287 512
851.985 2 2 25 256 256 0 0 0 0 0 0 0 0.0 2 0 0 0 0 0 0 0 0 0.0 0.0 0 0
100 512 287 512
This means that we are still suffering the endpoint problem, right?
And from swift stdout,
zzhang at login6.surveyor:~/swift/etc> swift -sites.file ./sites.xml
-tc.file ./tc.data -ip.address 172.17.3.16 first.swift
Unable to find required classes (javax.activation.DataHandler and
javax.mail.internet.MimeMultipart). Attachment support is disabled.
Swift svn swift-r2140 cog-r2070
RunID: 20080721-1748-m9d39dg9
Progress:
echo started
Progress: Executing:1
Swift kept waiting, which mean the -ip.address doesn't work as we expexted.
zhao
Ioan Raicu wrote:
> So Zhao, did it actually work, but you got those two errors and wanted
> to know what the errors were? If things worked as expected, then you
> should be fine, you can ignore both of those errors (I think). If
> things didn't work as expected, then we need to dig deeper to find out
> why.
> Ioan
> Mihael Hategan wrote:
>> On Mon, 2008-07-21 at 17:38 -0500, Ioan Raicu wrote:
>>> This error should just be a warning... as it tries a different port
>>> until it finds a good one. It should only print an error when it
>>> gives up. So, that is not your problem Zhao, especially as you seem
>>> to have run OK, right?
>>> Line 11: Final status: Finished successfully:1/
>> Yep. Sorry. Spoke without knowing.
> Ioan Raicu
> Ph.D. Candidate
> Distributed Systems Laboratory
> Computer Science Department
> University of Chicago
> 1100 E. 58th Street, Ryerson Hall
> Chicago, IL 60637
> Email: iraicu at cs.uchicago.edu
> Web: http://www.cs.uchicago.edu/~iraicu
> http://dev.globus.org/wiki/Incubator/Falkon
> http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
More information about the Swift-user
