[Swift-user] Re: A naive run of Falkon+Swift on BGP login node.
Ioan Raicu iraicu at cs.uchicago.edu
Mon Jul 21 17:36:03 CDT 2008
Zhao Zhang wrote:
> Hi,
> I started a test on BGP login nodes, running falkon service and swift
> on Login6, and a worker on Login2.
> Good news is I got the output file. Swift return successful. Bad news
> is there are some problems I don't
> understand.
> The swift stdout:
> /Line 1:    zzhang at login6.surveyor:~/swift/etc> swift -sites.file
> ./sites.xml -tc.file ./tc.data -ip.address 172.17.3.16 first.swift
> Line 2:    Unable to find required classes
> (javax.activation.DataHandler and javax.mail.internet.MimeMultipart).
> Attachment support is disabled.
> Line 3:    Swift svn swift-r2140 cog-r2070
> Line 4:    RunID: 20080721-1713-zkz78kcf
> Line 5:    Progress:
> Line 6:    echo started
> Line 7:    error: Notification(int timeout): socket = new
> ServerSocket(recvPort); Address already in use
> Line 8:    Waiting for notification for 0 ms
> Line 9:    Received notification with 1 messages
> Line 10:    echo completed
> Line 11:    Final status:  Finished successfully:1/
> 1. What is the exception in Line 2? is this ignorable or not?
This is not a Falkon provider exception, so I don't know.
> 2. What is the error in Line 7? Is it printed by swift or the
> deef-provider? Is this ignorable or not?
You can ignore this, it should really be just a warning.
> The following exception from Falkon only occurs when I specify the
> ip.address property in swift
> The falkon stdout:
> /2008-07-21 17:00:46,325 ERROR handler.AddressingHandler
> [ServiceThread-6,invoke:120] Exception in AddressingHandler
> AxisFault
> faultCode:
> {http://schemas.xmlsoap.org/soap/envelope/}Server.userException
> faultSubcode:
> faultString: java.io.IOException: '' For input string: ""
> faultActor:
> faultNode:
> faultDetail:
>        {http://xml.apache.org/axis/}stackTrace:java.io.IOException: ''
>        at
> org.apache.axis.transport.http.ChunkedInputStream.getChunked(ChunkedInputStream.java:161)
>        at
> org.apache.axis.transport.http.ChunkedInputStream.read(ChunkedInputStream.java:53)
>        at
> org.apache.xerces.impl.XMLEntityManager$RewindableInputStream.read(Unknown
> Source)
>        at
> org.apache.xerces.impl.XMLEntityManager.setupCurrentEntity(Unknown
> Source)
>        at
> org.apache.xerces.impl.XMLVersionDetector.determineDocVersion(Unknown
> Source)
>        at org.apache.xerces.parsers.XML11Configuration.parse(Unknown
> Source)
> Source)
>        at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
>        at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown
> Source)
>        at org.apache.xerces.jaxp.SAXParserImpl.parse(Unknown Source)
>        at
> org.apache.axis.encoding.DeserializationContext.parse(DeserializationContext.java:227)
>        at org.apache.axis.SOAPPart.getAsSOAPEnvelope(SOAPPart.java:645)
>        at org.apache.axis.Message.getSOAPEnvelope(Message.java:424)
>        at
> org.apache.axis.message.addressing.handler.AddressingHandler.processServerRequest(AddressingHandler.java:328)
>        at
> org.globus.wsrf.handlers.AddressingHandler.processServerRequest(AddressingHandler.java:77)
>        at
> org.apache.axis.message.addressing.handler.AddressingHandler.invoke(AddressingHandler.java:114)
>        at
> org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
>        at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
>        at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
>        at org.apache.axis.server.AxisServer.invoke(AxisServer.java:248)
>        at
> org.globus.wsrf.container.ServiceThread.doPost(ServiceThread.java:664)
>        at
> org.globus.wsrf.container.ServiceThread.process(ServiceThread.java:382)
>        at
> org.globus.wsrf.container.ServiceThread.run(ServiceThread.java:291)
>        {http://xml.apache.org/axis/}hostname:login6
> Ioan, any idea about this?
Not really sure what is wrong.  Try to fix the exception from line 2
first.  Also, Falkon is using GT4.0.x, is Swift still on GT4.0.x libs?
Ioan
> I am also attaching the swift log, could anyone check this to tell if
> there is a problem there, and most important thing
> is that if swift is using the IP address I specified in the
> --ip.address parameter?
> Thanks so much for the help
> best wishes
> zhangzhao
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
More information about the Swift-user mailing list
