[Swift-user] BioInformatics app question
Ben Clifford
benc at hawaga.org.uk
Tue Jul 15 05:30:41 CDT 2008
this is not particularly elegant, but it will mostly do what i think you
want:
make two custom mappers as shell scripts:
$ cat inmapper
#!/bin/bash
i=0
ls data/* | while read n; do
echo [$i] $n
i=$(( $i + 1 ))
done
and medmapper contains:
$ cat medmapper
#!/bin/bash
i=0
echo [$i].left ${n}.left
echo [$i].right ${n}.right
i=$(( $i + 1 ))
done
This pair relies on the fact that mapping will happen at the start and
that ls will return files in the same order in both of them.
Then you can use them like this:
type file;
type medfiles {
file left;
file right;
(medfiles o) preprocess(file i) {
o.left = touch();
o.right = touch();
compare(file l, file r, medfiles lm, medfiles rm) {
trace("comparing ", at l," and ", at r);
process(lm.left);
process(rm.left);
(file f) touch() {
app {
echo "hi" stdout=@f;
process(file f) {
app {
cat "/dev/null" ;
file inputs[] <ext;exec="./inmapper">;
medfiles intermediates[] <ext;exec="./medmapper">;
foreach input,i in inputs {
intermediates[i] = preprocess(input);
foreach left, il in inputs {
foreach right, ir in inputs {
compare(left, right, intermediates[il], intermediates[ir]);
Also, because the intermediate files are stored in the same directory as
the source data, and there is nothing in the mappers to detect if a file
is an input or intermediate file, then if you run the same workflow twice
you will find the previous generations .left and .right files being picked
up as inputs. You will need to rm -v data/*.left data/*.right between
runs. This could be fixed in the mappers in a couple of ways, left as an
exercise to the reader.
A more elegant solution might involve the mapper for intermediates[] doing
a transform on the way that inputs[] is mapped, but there is no mapper to
do that at the moment in a way that is useful here. (I have some thoughts
about what it would look like but they are not developed enough for
implementation).
More information about the Swift-user
