[Swift-user] Re: No response of Swift run
Mihael Hategan hategan at mcs.anl.gov
Sun Jul 6 22:04:36 CDT 2008
On Sun, 2008-07-06 at 12:29 -0500, lixi at uchicago.edu wrote:
> >Could you do the following for me:
> >1. edit dist/vdsk-xyz/bin/swift
> >2. replace the 'OPTIONS=' line with 'OPTIONS="-Xdebug
> Xrunjdwp:transport=dt_socket,address=8888,server=y,suspend=n"
> ' (a
> >single line) (you may need to do this every time you
> compile swift)
> >3. then run it again and let me know when it hangs. Don't
> kill the
> >hanging workflow. Let it hang instead.
> >4. Also let me know what machine you run this on.
> Today, I ran a workflow with 5001 jobs using swift-debugger,
> but it finished with error message:
> ERROR: transport error 202: handshake failed - received >GET
> http://www< - excepted >JDWP-Handshake< ["transport.c",L41]
> This is the first time for me to encounter this error. The
> log file is on
> CI: /home/lixi/newswift/test/newversion/0706/workflowtest-
> 20080706-1134-o8s4a3ig.log
Well, probably somebody was nice enough to portscan that machine while
the workflow was running. I guess there isn't any easy solution to this.
Maybe somebody else has a better idea.
> Thanks,
> xi
More information about the Swift-user mailing list
