[Swift-user] Re: No response of Swift run
Mihael Hategan
hategan at mcs.anl.gov
Wed Jul 2 10:12:44 CDT 2008
Could you do the following for me:
1. edit dist/vdsk-xyz/bin/swift
2. replace the 'OPTIONS=' line with 'OPTIONS="-Xdebug
-Xrunjdwp:transport=dt_socket,address=8888,server=y,suspend=n"' (a
single line) (you may need to do this every time you compile swift)
3. then run it again and let me know when it hangs. Don't kill the
hanging workflow. Let it hang instead.
4. Also let me know what machine you run this on.
On Wed, 2008-07-02 at 08:07 -0500, lixi at uchicago.edu wrote:
> >Hi,
> >I launched a Swift workflow (including 2001 jobs) at 16:16
> >yesterday. At 17:20, it returned the results of 2000 jobs,
> >then there is no reponse any more. I wonder why? I enabled
> >the replication option.
> >The log file is very large (more 1G) and is on CI:
> >/home/lixi/newswift/test/newversion/workflowtest-20080629-
> >1616-c4h22j03.log
> >Please check it, thanks
> The similar execution result occurred again. The log file is
> on CI:
> /home/lixi/newswift/test/newversion/0701/workflowtest-
> 20080701-1206-sjuu3cnc.log
> Thanks,
> Xi
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
