[Swift-user] Passing hostType for MPI jobs
Andriy Fedorov
fedorov at cs.wm.edu
Wed Jul 2 10:01:02 CDT 2008
> But finally...
> <extensions>
> <resourceAllocationGroup>
> <hostType>ia64-compute</hostType>
> <hostCount>5</hostCount>
> <cpusPerHost>1</cpusPerHost>
> </resourceAllocationGroup>
> </extensions>
> allocates 5 hosts.
> So it looks like you need to specify both hostCount and cpusPerHost.
Ok, I tried that. It indeed allocates correct number of the requested
hosts. But, there's still a problem. It appears that only one instance
of the executable is running, at least when I specify jpbType to mpi.
I am not sure it is being run as an MPI job. I have a simple mpi code
that outputs rank and COMM_WORLD size, ant the test says I have the
total of 1 process, when I submit my job with the following job
specification:
<executable>/home/fedorov/local/bin/hello_mpi</executable>
<stdout>/home/fedorov/scratch/hello_mpi_xml.stdout</stdout>
<stderr>/home/fedorov/scratch/hello_mpi_xml.stderr</stderr>
<maxWallTime>10</maxWallTime>
<jobType>mpi</jobType>
<extensions>
<hostType>compute</hostType>
<hostCount>4</hostCount>
<count>4</count>
</extensions>
Ben, can you try to run some MPI executable, and see if it works for you?
By the way, I also discovered, that sometimes the order of tags in
.xml makes difference (meaning, with certain order of "count",
"walltime" and "hostCount" globusrun-ws will abort). I had no idea
order matters...
Andrey
More information about the Swift-user
