[Swift-user] Passing hostType for MPI jobs
    Ben Clifford
    benc at hawaga.org.uk
    Wed Jul  2 03:34:35 CDT 2008
So:
<job>
  <executable>/bin/hostname</executable>
  <directory>/home/benc/mpi</directory>
  <stdout>/home/benc/mpi/test.stdout</stdout>
  <stderr>/home/benc/mpi/test.stderr</stderr>
  <hostCount>3</hostCount>
</job>
allocates three hosts for me, without specifying the type. This seems to
give the correct behaviour.
<job>
  <extensions>
    <resourceAllocationGroup>
      <hostType>ia64-compute</hostType>
    </resourceAllocationGroup>
  </extensions>
</job>
allocates one host for me (ignoring the hostCount) but it is of the
correct type, ia64-compute. This seems to be incorrect behaviour because
it ignores the hostcount.
A different approach, using a different hostcount field that the job
extensions web page at
http://www.globus.org/toolkit/docs/4.0/execution/wsgram/WS_GRAM_Job_Desc_Extensions.html
suggests:
<job>
  <extensions>
  </extensions>
</job>
results in:
[benc at tg-login1 mpi]$ globusrun-ws -submit -Ft PBS -F
tg-grid.uc.teragrid.org -job-description-file ./gram4-dbg.rsl
Submitting job...Done.
Job ID: uuid:cc6b465e-4810-11dd-9981-0007e9d811ce
Termination time: 07/03/2008 08:28 GMT
Current job state: Failed
Destroying job...Done.
globusrun-ws: Job failed: The executable could not be started.
qsub: Job exceeds queue resource limits MSG=cannot locate feasible nodes
Likewise if I use this extension:
      <cpuCount>3</cpuCount>
But finally...
  <extensions>
        <hostCount>5</hostCount>
        <cpusPerHost>1</cpusPerHost>
  </extensions>
allocates 5 hosts.
So it looks like you need to specify both hostCount and cpusPerHost.
So that is how to specify it with GRAM4 direct submission.
I'll have to have a play around to figure out how that can be specified in
Swift+GRAM4.
More information about the Swift-user
