[Swift-user] tcp.port.range in Swift 0.6
Andriy Fedorov fedorov at cs.wm.edu
Wed Aug 27 15:08:59 CDT 2008
Hello,
It appears to me that Swift 0.6 does not handle properly custom
GLOBUS_TCP_PORT_RANGE.
In the previous release, I used env variable $GLOBUS_TCP_PORT_RANGE to
set this range.
In the current release, it seems like tcp.port.range can be specified
in etc/swift.properties.
I still have the env variable, and tried to specify the port range in
swift.properties, and I tried passing it as -tcp.port.range, but Swift
keeps opening ports outside the specified range, as reported by
netstat. The same simple test script works with 0.5, but not with 0.6.
This seems like a bug to me.
Andrey Fedorov
Center for Real-Time Computing
College of William and Mary
http://www.cs.wm.edu/~fedorov
More information about the Swift-user mailing list
