[Swift-user] Returning arrays of files
Ben Clifford
benc at hawaga.org.uk
Tue Aug 26 03:34:21 CDT 2008
Probably what is happening is that in the below section, Swift can't deal
with mapper parameter inputs being constructed dynamically. One day
hopefully it will be able to - it makes sense in the language.
This situation is a bit annoying - you could use simple mapper if these
were input files...
> string bImageNames[];
> iterate i {
> bImageNames[i] = @strcat("block_",i,".nii.gz");
> wImageNames[i] = @strcat("window_",i,".nii.gz");
> }until(i==numPoints-1);
> file bImages[]<array_mapper;files=bImageNames>;
More information about the Swift-user
