[Swift-user] Need help debugging strange problem...
Ben Clifford
benc at hawaga.org.uk
Thu Aug 7 10:27:13 CDT 2008
there is a somewhat common misconfiguration of gram4 on the server side
where it is wired into the local queueing system incorrectly so that
completion notifications do not find their way back. this matches the
symptoms you describe - that fork works but that pbs doesn't, but that the
job apepars to have run.
I just tried a submission using the GT4 command line job submission
command:
$ globusrun-ws -submit -F
https://grid-hg.ncsa.teragrid.org:8443/wsrf/services/ManagedJobFactoryService
-Ft Fork -job-command /bin/hostname
Submitting job...
but it appears to hang without submitting. not sure what is happening with
that site...
Aside from that, my advice for diagnosis would be to try the above command
with both Fork and PBS and see if you get the same difference in behaviour
between the two.
More information about the Swift-user
