[Swift-user] Re: [falkon-user] 1) disable retry mechanism and 2) continue on failure?
Zhao Zhang
zhaozhang at uchicago.edu
Thu Apr 3 04:51:04 CDT 2008
Hi, Ben
Check this
login.ci.uchicago.edu:/home/zzhang/info.tar
zhao
Ben Clifford wrote:
> On Wed, 2 Apr 2008, Ioan Raicu wrote:
>> 1 Node Perf Falkon Swift+Falkon Swift+Falkon (patched)
>> Min 63.618 53.782 169.139 58.538
>> Average 64.76 65.47253 309.1945 80.21246
>> Median 64.74072 64.774 313.5535 76.5245
>> Max 65.863 94.447 605.654 115.237
>> Standard Deviation 0.488984 3.863944 52.13821
>> 10.95652
>> Efficiency 100% 99% 21% 81%
>> The first column shows the per task statistic when running on 1 node (4 CPUs)
>> through Falkon. The second column are the statistics for running the
>> application at large scale, on 2048 CPUs. The 3rd column is running
>> Swift+Falkon (both from SVN) on 256 CPUs. The 4th column is Swift+Falkon, but
>> Swift has the 3 patches applied. Essentially, the per task execution time was
>> reduced from 309 seconds to 80 seconds, where the ideal would have been 64
>> seconds. It brought the efficiency from 21% to 81% for this particular
>> workload. This looks fantastic!
> The standard deviation is quite large for the patched-swift values. I'd be
> interested to see the -info files for all of these runs so I can see what
> they are doing. Can you put them somewhere for me?
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20080403/77760e8c/attachment.html>
More information about the Swift-user
